Thanks for all the feedback guys. I've done some digging (googling) since the posting and the writeup at the first site from the search on lux meter produced by globalspec (
http://optical-components.globalspe...nents/optoelectronics/lux_meters_light_meters) stated that "... The standard color temperature for the calibration of most
lux meters is 2856° K, an amount that is more yellow than pure white." At the second site (
http://www.action-electronics.com/lightmeter.htm) , one of the model apparently can yield better result up to "±4% accuracy is enhanced by selecting lighting type (Tungsten/Daylight, Fluorescent, Sodium, Mercury) ". I assume that means recalibrating the peak of the reading to different color temperature (and perhaps the width of the spectrum as well).
Doug came up with 2 different coefficients (X1.39 for LEDs and X1.62 for incand) for converting his output measurements to lumen estimation. And he acknowledged that the discrepancy between LED and incandescent measurements may be due to "
different spectral detection characteristics of the sensor in the meter". Nerdgineer suggested that the incand coefficient (X1.62) is used for HID. That still puts PL24-S with 20% lower output than 10X :sigh:. I'm a big fan (in spirit that is) of HID lights so I'll just optimistically assume that there is still some uncovered specturm difference from LEDs and incandescents such that the actual coefficient for HID is different from these 2 figures (hopefully >2 :naughty
, and that 1300 lumens in HID is actually not worse off than 500 lumens in incandescent lights
(that is not to discount or disrespect all the fine technical work done by Doug and many more of you out there).
And of course there's the statistical approach pointed out by Handloraesing and many of you that's probably not used by the manufacturers so there's probably a glaring inconsistency among all claimed outputs, and many many many more.... :hairpull:
Well I guess if I let all these things bother me I'll never buy anything so I'll just stick to my original plan. I would think that 400 lumens or 1300 lumens is a huge leap anyway considering the fact that i'm using an E1L now.
Thanks guys
