the reason i say "sort of" is because the light i want to build is essentially the same concept that you guys have. that is, to have a head on one end, and a battery housing on the other, with the wiring in between.
this light will be for coon hunting, and pretty much modeled after the belt lights they sell for that purpose. but i want to use the head of a D mag light, cut it behind the switch, cap it with the existing tail cap, throw away the remaining tube, then run wire to a battery housing that would hold 4 ~2600mah Li-on batteries, pushing a P7, with a DW driver with a 100/70/25/5 mode.
i started this thread, and the guys really helped me a ton, and they seen that what i needed was what you guys do, except without all the water proofing... but the wiring would/could be the same.
so here is my question, im having trouble with the terminology on the parts of the light that i need to learn how to wire. like the tail cap that will go on the head, those bladder connectors, what type of wire and ect.... i tried a search and found a few threads with pics of the lights already built, but not the individual components. im not sure if i want to house the driver with the batt pack or not, at first i did, but with the extra room in the head, im not sure if that would be just as good of a spot for it in that extra space between the switch and the relocated tailcap.
can anyone tell me some terms to search for, so i can find some threads that show how the wiring and tailcap build is done? and also, what kind of wire im looking for, with that reinforced rubber on the ends, that prevent kinking and bending that breaks the wire over time.
-thanks guys.
-thanks guys.
