making reprt
***LED***
i got SST-50 LED by purchasing the
flashlight (SKU 32592) form DX. it was cheapest when i bought.
FYI: this light has NO driver or regulator! nothing on the PCB. but really bright one.
the LED was very tightly glued to the heat sink. so i got it by drilling the heat sink.
***LENS***
this is a frontal lens got from a junk telephoto lens of SLR. focus length is about 85mm. effective diameter 48mm.
moving lens mechanism is the same as previously reported ie using two magnet rings.
i tried to restrict the magnet filed with iron wires but no significant difference was observed.
***HEAT SINK & BRIGHTNESS CONTROL***
heat sink is 3 aluminum plate 1mm thickness.
regulators are 4x
1400mA AMC7135 board (SKU 1886).
left pict shows first wiring. i checked the current and found thin wiring was not enough
for much current and exchanged the wire for thicker one.
mode change mechanism is very simple.
low: 1x1400mA 7135 board
mid1:2x1400mA 7135 board
mid2:3x1400mA 7135 board
high:4x1400mA 7135 board are respectively effective.
very high: direct drive
i tested about its current not a little. ill report the results:
battery: 4x18650(2500mAh) parallel initial voltage 4.1V.
current measured by cheap DMM & usual cord
1) 4x7135board ->4.24A (expected current 5.6A)
2) direct drive--->5.24A over
3) 1x7135board-->1.41--1.45A (expect 1.4A)
4) 2x7135-------->2.9A (2.8A)
5) 3x7135------->4.1-4.15A(4.2A)
6) 4x7135------->4.41A(5.6A)
i made hall IC switch & tested it (FET:30V. 30A, 40mOhm)
the maximal current was 3.26A with 4x7135 boards.
double the FET 3.67A.
but using simply a toggle switch the current was 4.8A with the same wiring.
*no switch
only 2 FETs parallel:
1)1x7135board-->1.41-1.45A
2)2x7135board-->2.76-2.79A
3)3x7135board-->3.05A
4)4x7135board-->3.07A
1x FET:
2)2x7135board-->2.54-2.81A
3)3x7135board-->2.74A
4)4x7135board-->2.81A
final voltage is 4.07V.
i exchanged the thin wire fore thicker wire as shown at above pic.
1x7135board, 2x7135board same as with thin wire.
3x7135board-->3.68A
4x7135board-->4.07A
Conclusion:
thick wire is necessary to keep much current.
this FET can be used for 2x7135board (2.8A) around this voltage (4.1-4.07V).
a cheap toggle switch (125V, 3A) is very good.
a hall IC switch (i made) is interfered with wiring around 2.5A current.
so i decided to use a toggle switch for this light control.
***WHOLE ASSEMBLY***
connection of lighting, switch and battery parts was not so easy.
it is necessary to keep strength and to be disaasembled easily.
connecting plate were all hand made of aluminum.
explanation of assembly is difficult for me. sorry only show the picts.
after assembly i checked the current with full charged batteries (4.2V) again.
1) 1x7135board-->1.42-1.44A (expected 1.4A)
2) 2x7135board-->2.88-2.90A (2.8A)
3) 3x7135board-->4.35-4.40A (4.2A)
4) 4x7135board-->5.79-5.88A (5.6A)....over drive!
5) direct drive--->10A over!! .......umh dangerous!!!
thank you.
