Multiple output is a nice feature, but I'd prefer it the regulation was done before LED and I hate PWM.
PWM is ok for incans and motors since they have an inertia to ride through, but when it's used on LEDs, the resulting light flickers worse than old school fluorescent lights (which operates at 100 or 120Hz, because line cycle consists of a negative and a positive cycle and the lamps light up on both waves). Sinewaves don't spend much time at zero unlike PWM pulses that spend all of non-on time at zero.
As perceived by my eyes, flickering is even more noticeable at lower on-duration (duty cycle) even with a frequency around 150-400Hz, which seems to be a common range for many flashlights.
The phosphor in fluorescent lamps have a longer persistence than LEDs, so the effect isn't too bad. Flickering is noticeably worse on LED powered Christmas lights and such. HIDs are not nearly as bad as LEDs either as the capsule burns orange hot from heat which provides some light even during zero crossing to cushion visible flickering
