cmaylodm said:I'd also like to add that reverse clickie switches won't go off in your pocket accidentally if the switch is depressed.
Calina said:I like reverse clickies. They allow us to have those cool U.I. which are not possible with forward clickies.
TORCH_BOY said:I have always liked the normal Clickie on my lights as I like the momentary on feature
Ah, I was just going to say that. I carry a TLE-5'd mini-m@g with a TerraLUX reverse clickie around at work, in my back pocket. I can sit down, etc., and it's never accidentally come on. I can also shove in down into the original m@g pouch hard and it still doesn't come on.cmaylodm said:I'd also like to add that reverse clickie switches won't go off in your pocket accidentally if the switch is depressed.
I think you already have it. Call it price or simplicity of construction, it amounts to the same thing. No other reason I can think of.Mash said:Given the general dislike for reverse clickies (me included), apart from the mentioned price factor, is there any reason they are still used in simple (ie no UI requirements) lights?
Absoltuely agreed. Those switches are essentially variable capacitors, and there are no breakable components in them. They can aslo be made to be absolutely silent as well as there's no "latching" mechanism needed. Finally, I love the feature of the Photon Freedom where click and hold (while off) causes it to start up dim and gradually increase in brightness, or clicking and holding while it's already on causes it to dim. A twisty-switch, or one of those magnetic dials (again -- no mechanical contacts to break) to act as a permanent "lockout" though may be a good idea with that sort of interface, to prevent accidental turn-on. Or simply clicking the button a few times fast to switch between momentary and static on/off would work as well.Flashlights should use electronic clickes, like the ones used in keyboards, a tap for constant on and holding the clicke for more then 1 second is momentary on(and I've never seen a electronic clicke break).
Don't electronic clickies have a small leakage current?Gunner12 said:Flashlights should use electronic clickes, like the ones used in keyboards, a tap for constant on and holding the clicke for more then 1 second is momentary on(and I've never seen a electronic clicke break).
TorchBoy said:Don't electronic clickies have a small leakage current?
xiaowenzu said:Reverse Clickies come on too easily in my pocket. I don't like 'em!
jlomein said:Ummm...don't you mean the opposite? A normal clickie with momentary on would turn on if only slight pressure is applied. A reverse clickie needs to be clicked all the way before you get light.
