Ah ha. So, warm does not = high CRI?
Correct
Is the Q5 a high CRI?
Thanks.
After manufacture, Cree LEDs are "graded" by Cree. One of the criteria that Cree measures is efficiency, specifically the brightness (more precisely, the luminous flux) at 350 mA of current. Q5 is the group code for the efficiency bin of Cree LED models XR-E, XR-C, XP-C, XP-E, and XP-G that produce between 107 and 114 lumens at 350 mA.
The LEDs are also graded according to their white chromaticity region, aka their color temperature.
As far as I know, Cree does not grade those LED models according the the CRI value. I don't know what kind of range their CRI values fall into. The XR-E and MC-E model Cree emitters I have, ranging from neutral to cool do not render colors very well compared to my incan lights.
One possibility that hasn't been mentioned (or maybe I just missed it) is a AA MagLite or a MagLite Solitaire using Eneloops rechargeable cells. If I understand correctly, the NiMH cells quickly drop to 1.2-1.3 V, but then remain at that voltage for most of the remaining duration of their discharge. That might be a suitable substitution for a regulated light, while offering the possibility of an inexpensive, low output light with an incandescent lamp. A fresh charge before each shift should be more than enough to get through a shift.
Lithium primary cells, e.g., Energizer Ultimate Lithium, also have a flat discharge curve compared to alkaline primary cells, but as has been mentioned already, their higher voltage might blow the lamp.
