Does anyone know how much brighter the E1e is compared to the mini mag?
Does a bulb exist that could handle the Energizer Lithiums better than the stock bulb that comes with the min-mag? If so, do you know how much they run, brightness level, duration, and most importantly where to get them?
Thanks.
I have no personal experience but from looking at some old CPF threads it seems that there is a xenon bulb called the Brinkman Nexstar that has no problem handling the increased voltage from 2xAA lithium cells in a minimag. Reports were that these upgrades increased the output of a minimag to near-E1e levels.
There was another bulb that some had tried, the Radio Shack 272-1150 Krypton Mini-Flashlight lamp, but this seems to not be available anymore.
Stock minimag bulbs are so cheap, you could also try carrot's suggestion and just see what happens with those.
I know that the ripoffs holsters are clip on, the nite ize holsters are clip on, and some of the surefire holsters are clip on. Howver these holsters tend to use Velcro flaps which can be kinda loud.
The only production regulated incandescent light is the A2. Since there are no other regulated incans, there are no AA-based incans that are regulated. You should definitely stick to CR123 in this application. Even the better Xenon-based incans (as compared to Krypton Maglites) as offered by Pelican and UK cannot offer better runtime since the output is directly related to the discharge curve of the battery. CR123's have a discharge curve that is very close to being flat, so they are perfect here.
That should be the case, however Energizer Lithium AAs are higher voltage than regular alkalines or NiMH so they may actually blow the bulb instead. Give it a shot if you like.
Well, I would probably get one though it has the clip. Just to protect it from any major scratches & such.
I am drawing a blank on where to get flashlight holster that clip over the belt, without having to draw the belt through the holder. A specific name/website has been mentioned on here quite a bit before. Anyone know?
Whilst I think a Surefire E1e would be a great solution... would a Mini maglite's bulb be able to "handle" the output of a 14500 (used with an AA dummy cell? :thinking:
So, bascially, one that on low is like a mini maglight, but regulated. Prefer with a high. LED may be a possible choice, IF the color rendition is as good as incand (crucial so the color of the steak is true & not off).
Thanks for your help.
2 questions: Do you think a diffuser on a SL Strion would bring it down quite a bit to be used for such applications?
Do you know where to get a cheap diffuser that stays on either the E1e or the SL Strion?
Thanks.
No you would have to replace the bulb with something like a strion bulb and then it would be a great deal brighter. There used to be a ceramic socket that could be purshased to create such a ligh but it's long since been sold out.
