Yes, that is my concern. Some of the lights I have been seeing, would be too bright in this kind of setting. How bright is the Ra on at a low setting? (assuming there is more than 1)
The icand mini-mag is about right for the situation, but it drops to quickly. So, I am looking for something that puts out a steady stream of light without dropping after 5 mins like the mag. & if possible, a high, so I can switch it out as my EDC
Did you miss the application? Color rendering is useless if one is blinded.
93 is the highest posted CRI # available for an LED that I know of. Output is going to take precedence because if the output isn't right then the question is moot.
Although if 93 wont cut it, the mini/micro mag will have to do becuase it is the only incan around with a low enough output.
Hmm.. I have never been in an upscale restaurant where you could not see the food clearly even by candalight.
You are wrong and ignorant. There are a lot of pocket dive lights that are incandescent and far superior to the Mini Maglite while still maintaining a similar output level.
Also, the Surefire E1e is an excellent pocketable size, and well-suited to the task. I recommend it highly. At 15 lumens it is certainly not too bright and will be excellent for the OP's needs.
Here is another light that the OP might choose, though not nearly as nice as the E1e.
http://www.tek-tite.com/src/product_info.php?id=791
In the OP's application, CR123 is the preferable power source since it maintains a similar output over time without the usage of a regulation circuit.
Since they can be had rather inexpensively online from various dealers (such as Lighthound and 4sevens), there is no issue of procurement.
The only production regulated incandescent light is the A2. Since there are no other regulated incans, there are no AA-based incans that are regulated. You should definitely stick to CR123 in this application. Even the better Xenon-based incans (as compared to Krypton Maglites) as offered by Pelican and UK cannot offer better runtime since the output is directly related to the discharge curve of the battery. CR123's have a discharge curve that is very close to being flat, so they are perfect here.Does a flashlight exist with AA? Basically, I like how LED regulate the light & you get the exact same amount of light wether you turned it on or 2 hours later (of course depending on the setting). That just doesn't happen with the Maglites. I would feel a little bit better if using AA batteries & discarding them, though they still have power left but not for incand, then the 123's. But, that's me. Of course like many of you, I would like to get as much run time & juice from my batteries to begin with, lol.
But, would the Ra w/ high CRI be too bright for this?
Yes, I am not looking to blind someone, lol. I alreayd have a SL Strion, but that may be too bright. If the plates weren't white & reflecting the brightness of it, I'd stick with that. But, such is not the case.
As a Chef who has plenty of experience in dark dining rooms I would say go with the E1e. A diffuser would be a great help IMHO, less focused light bouncing off of plates and silverware.
