Paul Baldwin
Hi,
a little while back I ordered a couple of these drivers. They are advertised on the DX site as 300mA. Reading the feedback it was apparent that they actually feed 700mA to the led which was what I wanted.
However, the latest ones I have do match the description and supply 300mA Infact I got 2 different driver designs in the same order.
The Dx site is down at the mo so I took a photo of the new and original drivers I have.
New Driver
Old driver
Is the resistor R15 in the top photo the one I have to change to alter the current and any ideas what sort of resistor I should replace it with to get roughly 700mA.
Sadly the original driver no longer works, it did until I started using a scalextric power supply that works at just under 16v, 12v was just fine though.
UPDATE. The sites up again now. I orderedhttp://www.dealextreme.com/details.dx/sku.13557 both times. From the discussion at the bottom of the page it looks like the chip used has changed to the PT4115 from the previous PT4110. I found a datasheet for it here www.micro-bridge.com/data/CRpowtech/PT4115E.pdf
Cheers
Paul.
New Driver
Old driver
Cheers
Paul.
