Kinvu
Are there any LED drop in's for a E2D. Thanks.
Right. An example of this is http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=2747."drop-in" is typically used to refer to an LED module (usually contains the driver, LED, and reflector, but sometimes just driver and LED) that drops in to the head. Take a look at a SF C/P/G/Z-series that uses the P60 LA. That, in an LED form, would be considered a "drop-in".
Exactly. And swapping a KL4 head onto an E2D would kinda negate the idea, IMO..
:twothumbsThat's an awesome looking E2D!
Hello,
I am new to this site and had some questions.
AzGB, What kind of sealer did ou use on the bezel? E2D is withouat a doubt my favorite flashlight (long story as to why). I havebeen wanting to do the same mod to mine. Howeve, I have never seen black KL4 assemblies. Whear, how did you get yours?
The photoes you posted are great.
I actually haven't resealed it. There was enough residual sealant, enough contact with the front o-ring, and I'm an Arizona desert dweller who doesn't encounter enough moisture to give it much thought.
As far as the Black KL4 head, it is available both as a standalone component from SureFire (SF Part# KL4-BK-WH ...
I hope this helps...
