Finally disassembled the duty belt to slide the SafariLand basket weave small light holster on the belt to use my Surefire E2DL for a 6p - 3a shift. Slid the light on to it's holster next to a Pelican 7060 that is on temporary duty while my Polystinger is being fixed under warranty by Streamlight (turns out I like the 7060 better than the Polystinger, but that's another matter). Also I really like the size of the E2DL.
After eleven or twelve vehicle stops, along with three hours at a vehicle checkpoint with state and local officers, and some other stuff, I found the E2DL the best light I have used on duty period. About midnight the lower forty degree weather turned to rain for the rest of the shift. Great not worrying about the light getting too wet (I had a Stinger fog at the lens after a heavy rain once). The broader beam was great for illuminating vehicle interiors, did superior illuminating a back yard looking for a motorcycle.
The UI was perfect for this kind of work. Click, and you're at 200 lumens. Click down, and I could use the lower beam to check that a driver was wearing contacts when their license called for corrective lenses without driver discomfort; or use the low beam while filling out a vehicle inventory as part of impounding a van. The high is almost too bright for a field sobriety test, but works fine if you're mindful not to tan the subject with the center of the beam at the face. Great that you don't have to click through low beam every time for bright. I'll also mention that the LX2's UI was completely unacceptable for these applications, but I carry the LX2 in plain clothes. Tactically if needed, you still have the temporary beam with the E2DL.
Downside: A $21 box of batteries every six shifts if you change batteries each shift. Full time that can approach eighty dollars a month if you work nights unless your agency has the 123's. For a day shifter occasionally using a light, this is their light. A fresh pair of batteries did last the whole shift last night (and it turns out the remote for the Stalker model Doppler Radar takes the same battery, so I was actually able to replace someone's remote that was down). And, finally, except in very limited circumstances, you'd get written up or worse using the E2DL as a defensive weapon.
Anyway, except for the battery considerations, perfect!
