protein_man
The elly is being driven off a 14500 with a 1 ohm resistor inbetween. On a new cell it runs around 600mA. Nice cheap super bright light! 100 Lumens plus for aroun $20 delivered.
The converter is not a current regulator, it's a simple voltage step-up. If you throw in a higher-voltage battery, it simply wastes more of the power (I've tested this out by trying two, then three NiMH batteries), and gets extremely hot, without lighting up the LED much brighter. If you're going to run LiIon, then a direct drive setup is not bad -- the battery is already a close match to the voltage of the LEDs, so not a lot needs to be wasted in resistors to keep it under control -- also the discharge curve is fairyl level, so light output should be fairly consistent.I measured 1200mA at the battery however I dought the led is seeing the full 1200mA. It's a ripper of a torch and its super birght, but it just doesnt seem that bright. It's still the brightest light I own second to my modded elly!
2xTrinity said:The converter is not a current regulator, it's a simple voltage step-up. If you throw in a higher-voltage battery, it simply wastes more of the power (I've tested this out by trying two, then three NiMH batteries), and gets extremely hot, without lighting up the LED much brighter. If you're going to run LiIon, then a direct drive setup is not bad -- the battery is already a close match to the voltage of the LEDs, so not a lot needs to be wasted in resistors to keep it under control -- also the discharge curve is fairyl level, so light output should be fairly consistent.
Just thought it was worth quoting this from your web site X2X3X2 mine was exactly the same. Just received it this morning no time for testing yet (1:30PM) looks and feels good. Just checked the current draw, mine is only 860mA :thumbsdowSomething to take note of, the emitter module does not have any thermal paste applied between it and the star PCB. As can be seen from this image, the under side of the star is spotlessly clean. There's some hard rubbery substance in the middle cavity of the module, this doesn't make contact with the star either. I would recommend that you apply some thermal compound here before using the light for extended periods of time.
Norm said:From http://www.lightreviews.info/
Norm
Modded Elly. In the case of the U2, I don't know much about it, except that it's a stepdown converter of some sort, most likely current regulated. Though in the case of running and 18650, I think it's buck (stepdown) only, so once the battery voltage drops below 3.6, it will most likely direct drive from thereafter (gradually decreasing brightness, but longer overall runtime). This effectively gives you the choice of shorter runtime but higher, more consistent brightness with two CR123s, or somewhat lower brightness, that starts regulated, then gradually goes down, with much longer runtime.Trinity, are you reffering to the modded elly or the U2 Style?
I'm happy with the light and I'm sure you will be toomoon lander said:well thats a bummer but hey isnt 860ma like 110ma more than almost any other light? I just ordered mine 5 minutes ago (just before you posted this), do you think its still worth it?
That sounds almost like this light is a direct drive with a resistor. If that were true though, I'd expect the LED to be cooked almost immediately through it.Nake said:I've noticed a lot of different amp draws at the battery from this light. I got 1.7A with a fresh battery, and just before the protection kicked in after 90min it was 1.5A. In the reviews section thread, "Randy555" got 1.6A, I assume from a fresh battery. For a second I tried two cr123s and got 3A.
Mesured with the tailcap removed, so total current.moon lander said:have you checked the current going to the led? the current going to the regulator could vary, but the stated spec was 1200ma to the led. Norm was your measurement at the led or the battery?
2xTrinity said:That sounds almost like this light is a direct drive with a resistor. If that were true though, I'd expect the LED to be cooked almost immediately through it.
Something doesn't sound right there at all. 3A from 2 CR123s is almost 24 watts! Perhaps the circuit is drawing higher amounts of current in pulses, off and on, and that is throwing off your multimeter or something. Something that small consuming 24W would get extremely hot (take for example a 25W soldering iron...)
I have read though that there are multiple versions of this light floating around
x2x3x2 said:3A from 2xCR123 is a lot of power! Did yout light get hot or LED burn out?
