r2
Re: Elektro Lumens \'Blaster II\' 3 \'D\' Cells
Have you tried thw 5W emitter with your new optics yet? The Lumileds optics don't work as well with the 5W because of its bigger die size so I'm curious to see how your new optics fare. I hope the results are as impressive as they are with the 1W!
A few more questions if you don't mind:
A few people have made great progress in heat sinking the 5W and are finding they work better than expected in smaller bodies. Do you think the current Blaster II or even the Blaster I would work with a 5W?
Also, how do the dimensions of the Blaster compare to a Maglite? How about the interior diameter of the battery tube?
I ask because when all the components are available I'd like to make a light using a 2D maglite with 8AA batteries and a regulator (either the Badboy with 4AA x 2 in parallel or the Wizard if it is available with 8AA in series) driving a 5W emitter. I think the Blaster is a cooler design, though, and if everything works okay (heatsinking, optics, the fit of the battery tube, availability of the Blaster I) I may see if I can hire you to build one in a Blaster I body.
I'll probably pick up a stock Blaster II in any case just because it is so cool and I don't have a long running light.
- Russ
<font size="2" face="Verdana, Arial">Am I reading that right? That's almost twice as bright as Mr Bulk's LGI and several times brighter than most other 1W LS lights we've seen! Is there much spill or is all the light tightly focused?Originally posted by ElektroLumens:
When I metered it, I was shocked to see it measures at 1,557 lux!
- Russ
