Re: Elektro Lumens \'Blaster II\' 3 \'D\' Cells
Originally posted by woodbender:
What kind of warranty if any will you be offering and will you offer different led(color) options with this flashlight in the future? If the flashlight is warrantied, would adding glow powder in the head void the warranty? Just wondering since it is hard for most people on this forum to NOT modify a flashlight they receive. I look forward to receiving this light from you and seeing what other lights you come up with in the future. Thanks...Jeff
<font size="2" face="Verdana, Arial">I offer a 1 year warranty on parts and labor.
If it is opened up and modified, I don't think it is fair to expect me to cover damage caused by your modification. If I see it's been modified, I'll probably not cover the cost of replacing parts. For example, you open it up and remove the resistor, and the emitter burns up. It really isn't fair to expect me to repair it at my cost, is it?
Other than the emitter, there is really little you can do to damage it. Basically, it's fairly bullet proof. I will try to have lens and switches, two things that will probably get wear and tear and eventually wear out. The lens is 2mm thich acrylic clear, which is super easy to get ahold of. Also the switch is not hard to find and replace.
I expect people will make modifications. If you make a modification, you should expect to bear the cost if you damage something, right?
I suppose I'll be amazed at what some people will do to a flashlight.
Wayne J.
