Eneloop discharge at lower temperatures
BackBlast
I've never been able to find any data for these new low-self-discharge cells at low temperatures other than a bit of marketing liturature that says they work well. So I've run a few tests, each with 2 cells. The ambient temperatures varried a little during discharge, not more than 3 or so degrees and I'll indicate which direction.. Cells and C-9000 were left in the ambient conditions for 2 hours prior to discharge. Cells discharged at 400 mah.
Cells formed (and last charge) on Jan 9th for 1925 and 1933 mah capacity.
Discharged at 55 F (+3) for 1737 and 1755 mah capacity. (90%)
Cells formed (and last charge) on Jan 9th for 1967 and 1929 mah capacity.
Discharged at 39 F (-3) for 1750 and 1711 mah capacity. (89%)
Cell formed (and last charge) on Dec 31st for 1917 mah and Jan 2nd 1962 mah capacity.
Discharged at 27 F (-2) for 1715 and 1725 mah capacity. (89%)
I also ran some Enduros... Formed on Dec 31st for 2050 and 2050 mah capacity.
Discharged at 27 F (-2) for 1777 and 1758 mah capacity. (86%)
If your curious, all cells were formed with ambient temperatures of about 55-60 deg.
So far so good! Voltages appeared to hold up well and I haven't yet run into a real appreciable reduction in expected capacity. I just need to figure out how to go lower, I'm going to need to find some kind of freezer since winter here is warming up. Had I been more on the ball we had a few nights in the teens a few weeks ago. I believe this data already shows that both varieties are performing better than regular NiMH cells would.
