Bolster
So I purchased a good battery tester that tests under load, giving 20-40-60-80-100 readings. For long life and health of my new Eneloops, at what amount of discharge should I be recharging them? Thanks...
Thanks for the answer! Wish I understood better...sorry I am slow, I have newbie brain, can I get some clarification:
"...preferably before they get completly depleated below the speced .9 or 1V thing under load. then you wont reverse charge them."
My ZTS tester indicates as low as 20%. If I recharge when they hit 20%, will that take care of the problem of possible reverse charging? (No V markings with this tester).
Yes that would be perfect
"so just like any rechargable a cycle of them once in a while would be good.
relative to the self discharge, that would probably mean once in year or 2 . vrses once in 3-6 months like the others."
So, does a cycle mean complete discharge all the way to 0? What exactly is a cycle? If a cycle means complete discharge, doesn't that go against your warning above?
Yes it does go against my warning, if you dont know or have a machine that will discharge it to some safe level, then dont bother trying.
"if they start acting funkey on you , run a low discharge cycle and see if they perk up under load. the rest of the time, just top em off whenever."
Would a low discharge cycle be like running them in my L2D on low until the light's out?
An L2d as in series light, is not a great place to run then to the .9v, series meaning used with another cell stacked end to end. if that light goes OUT, stop using it (like dont keep retriggering it to work again) and recharge the cells.
" how were you going to top them off? because the charger can be a bit harsh on them, specially chargers that terminate only on overcharge."
I was going to use the bundled Eneloop 4-slot charger...which seems extraordinarily slow...overnight, basically. I don't know how it terminates. Would you consider the Eneloop charger that came with my Costco special "blue suitcase" Eneloop pack to be a slow charger? (I hope so!)
the enloop charger is sorta medium speed (only from the specs i saw) need more input, can you tell us more about the charger, and mabey what the back of the charger or the manuel says about the ma used to do a charge and termination method. or the exact time it takes in reality for it to fully charge. it should be ok. but i dont know enough to answer.
"topping them off with a slow charger when they only need a bit of juice, like the end topping charge alogrythm would be a good way to squeese them back up to the top, without going over overcharge spec."
So that's the heart of my question, really...most of my Eneloops are at 40 or 60%, and I want to know: should I go ahead and top them off when they reach the 40-60 range? Or should I let them drop further (say, to 20%) before recharging?
If there are only so many recharges available to these batteries (I read x1000), then that would indicate I should let them get low before recharging, and that topping off might just be using them up prematurely. (Sort of like guys who clean their gun barrels so often that they cause 'cleaning wear' to otherwise new guns)
Exactally, you said it right, clean the barrell carefully and when needed in thier dreams it will get 1000 charges, IF the charger is magically perfect topping it off often after a shallow discharge can be done 1000 times. if the charger is harsh at the end of charge then it would better not to. If the battery acts the same as most of the other stuff, you will get many more short runs and short charges than full cycles. if the charger is harsh , then it would be better to do it less.
at any rate it would be FAR better to have topped it off then for it to reach a fully discharged state in a series configuaration, and getting a "reverse charge"
Basically I want to learn good battery care habits as early as I can, and I 'preciate your help!
It appears that Eneloop's 2 cell charger (faq lists it recharging 2-4 hrs) is faster than its 4 cell charger (listed as taking 4-7 hrs). Could I conclude the 4-cell charger is therefore gentler on the batteries?
AND, the 64-dollar question, should I just buy an after-market slow charger? If so, can ya make me a recommendation that won't cost an arm or a leg?
do you want to plunk down 20-30-40-50- or 100 dollers?
No - you should never discharge NiMH cells down to 0 Volts. Once they get down to around 1 Volt, you've got pretty much all of the energy that you can out of them."so just like any rechargable a cycle of them once in a while would be good.
A cycle is just a discharge followed by a recharge.What exactly is a cycle?
No - that would be a bad idea. Because the L2D uses the same head as the L1D, it will discharge both cells down until their combined voltage is down to 0.9 Volts or so, which would mean that their average voltage would only be 0.45V and one of them could be even lower if they're not perfectly matched (i.e. one cell is capable of holding more charge than the other, so one cell runs out before the other and can go to zero or even be reverse charged)"if they start acting funkey on you , run a low discharge cycle and see if they perk up under load. the rest of the time, just top em off whenever."
Personally, if I was you, I'd charge them up before use, but if you need to use them first, that's also fine as well.So that's the heart of my question, really...most of my Eneloops are at 40 or 60%, and I want to know: should I go ahead and top them off when they reach the 40-60 range? Or should I let them drop further (say, to 20%) before recharging?
Like I said earlier, even if you charge them once a week, you'll probably get well over 2 years from them, so I wouldn't worry too much about wearing them out just from topping them up.If there are only so many recharges available to these batteries (I read x1000), then that would indicate I should let them get low before recharging, and that topping off might just be using them up prematurely. (Sort of like guys who clean their gun barrels so often that they cause 'cleaning wear' to otherwise new guns)
Use 200mA for 16 hours. But Tom says charge at the rate you expect to discharge at to keep them vibrant.I just bought some Eneloops AA and have them install in a FM 8AA holder wired in series. ... And if I want to slow charge it, ...
Also I read in the Eneloop FAQ that you must at least charge 2 at a time, and if doing two, they should either be together in the middle slots or to the slots at either edge.
I did a search, but could not find the Eneloop FAQ... Would you please provide a link? Thanks.
