Extreme HID Searchlight
Dr.K
Webster Parish Louisiana
Has anyone ever seen this? It is on sale at ebay, but apparantly no name brand. Here are the listed specs also.
I'm new to the HID game, so I'll let the more experineced flashers educate me on whether or not this might be a good light.
Thanks,
Technical Information:
Dimensions: 2.25 in. (at base) x 15.25 in. length
Weight: 2.50 lb
Lens: Clear Hardened Glass
Light Source: Proprietary 24W Metal Halide
Lumens: 1300±
Color Temp: 6000K
Battery: 12.0V / Lithium ion 5200mA
Ballast: Proprietary Electronic
Features:
Pre-focused spot beam
Easy access charger plug located in end cap
Over charge protection
Strap Rings
Nylon Carry strap
Corrosion resistant extruded aluminum
Protective rubber lens & end caps to absorb shock
Operating temperatures:
Operating: 0° - 40°C
Storage: -20° - 35°C, RH 45-85%
Charging: 10° - 30°
Charging System:
Battery charger: 100/240VAC, w/automatic over charge protection, 2 hr., charge.
Color: Anodized Black
Burn time: 140 min.
Every HID flashlight kit comes with in a secure lockable rubber harness, international charger, and Strap.
Yes Dr.K
That's the AE 24 Power light. It's a proven performer among HID enthusiasts. I have the 24/S which is the shorter version.
Here is the one that you have pictured
http://batteryjunction.com/24whidposupo.html
Here is the newer style by the same manufacturer
http://batteryjunction.com/aex25.html
Note that I'm not saying that the one on Ebay is a genuine AE. But the light pictured is an AE or an exact replica of it... buyer beware.
If you're considering one, I recommend purchasing from a reputable dealer associated with the forums here. Another option is to purchase one used from a CPF member.
I rolled the dice. The ebay seller only sells HID stuff, and had good feedback. In the description there was a direct comparison to the AE 24 light, and it was stated that they are produced at the same place in china. For the money savings (only paid 179.99 total) It will hopefully be worth it.
I'll post the results.
oao,
Kyle,
That is the generic ProLumens 24w HID light. Not as good as the AE but better than the Brightstar.
Well, I cranked this puppy up tonight. I am very impressed. Again, there is no reference point for me as I have never seen an HID flashlight before, but I can tell you that it shines on things so far away, unless it is a tree sized object, I wouldn't be able to discern it with my eyes anyway. I really don't think that paying twice as much could have got me twice as much light. However, I've been wrong before.
