HKJ
Also if anyone could enlighten me as to how to check mAh on the multimeter it'd be great
The setup is easy, but requires some dedicated work.
Place a 1 ohm 20 watt resistor across the battery, then measure the voltage each 5 minutes (More often gives better precision) and put the time and voltage into a spreadsheet. This will take a about 1 hour for a 3100mAh battery.
When finished you can add columns for time (in hours) between measurements and current.
The you multiply time and current and sum it together.
A hobby charger will do all that automatic and only cost $25 for the cheap models.
