JimmyM
I've hit upon an idea that will kind of bridge the gap between the existing JM-SST and a true regulated design.
It only really works when the battery voltage is high enough to pop a bulb when the pack is fresh and will be OK when the pack voltage has dropped a bit. Basically it raises duty cycle as pack voltage drops. It doesn't monitor output voltage. I started thinking about this while building nitnapz' Mag458. The pack voltage would pop the 458 when fresh so I had to dial back the duty cycle, but the lamp voltage dropped out of the "optimum" range as the pack settled down into the area where it would spend most of its discharge time.
Below is a solution for the above mentioned Mag458. Pack voltage would initially start at 26.1V, but the Bulb would see 19.95V. As the pack voltage drops (pink line) the RMS voltage dips a little (down to ~19.28V), then rises again.
From a Vbatt of 22V to the point where the FET is at 100% duty (19.98V) the RMS output is pretty steady (19.87-19.98V)
This isn't a regulator though.
Think of it as a soft-starter "plus".
It would require a little tuning by me or the user via 2 onboard pots. The design is scalable from a 5761 to one of petrev's 1100W monsters. 6V to 40V. Sorry Hyper-Blitz guys. The absolute maximum voltage is 42. After that the smoke comes out.
I still have to do some breadboarding to work out the kinks.
Thoughts?
Thoughts?
