I didn't have to boil my L0D. Perhaps mine had less glue on the threads.
The most important thing, is if you are going to attempt a brute force twist, keep the body screwed into the head. Otherwise you may squash the wall of the head as it is quite thin.
The emitter is just a straight swap. Avoid the wires in the head. Heat the small legs of the Lux III, as soon as the solder melts - suck it away with a solder sucker device - or you could use braid I suppose.
Put your thumb at the end of a knife blade only exposing the very tip of the blade. Insert under the Lux III and twist, be careful not to follow through as you may cut the small wires next to the emitter.
Clean out the waste thermal paste from the head.
Shorten the legs of the Seoul emitter using wire cutters. Don't make them too short - they should reach the outer diameter of the L0D head.
Cover the depression in the L0D head with a small amount of arctic alumina epoxy.
On the top of the head there are two sets of contacts, connected to two wires. One is
red, the other
black. If you look into the dome of the led, you will see two bond wires (gold coloured). Turn the led until the bond wires line up with the blob of solder at the end of the
black wire. Press down gently on the led (not too hard) to seat it in the epoxy.
I waited 6 hours for the epoxy to harden.
Bend down the legs of the emitter until they close to (or touch) the contact around the rim of the head. Solder in place.
Gently screw the head cover back on, it should go to full tightness with no problems. The hole in the reflector does not need to be altered.
All done !
