Hello,
Can anyone tell me how to remove the old emitter and how to put the new one in?
Yes. I just did a P2D Q5 mod.
I've remove the head already and want to put a q5 in it as opposed to the old cree p4.
Well, you are off to a good start!
1. how do you remove the old emmiter? use a small knife?
I used dental tools to scrape the adhesive off of the wires, and from around the emitter. Once I had the wires free of the adhesive, I pried the emitter off the pedestal with the dental tool. I unsoldered the wires, removed the LED and cleaned the area very well. Pay particular attention to the wires, as you do not want to damage them, or snap them off inside the head. ***Before you remove the emitter, make note of how it is oriented in the head. You will want to put it back in the same position so that the wires will reattach easily.
2. what kind of thermal compound are needed?
I used Arctic Alumina. It does not conduct electricity.
3. does the thermal compound have to be adhesive? since I already bought artic silver
I do not know about the Arctic Silver. I stopped using that when I began doing Seoul mods.
To attach the new Q5, mix a small batch of adhesive. (I recommend AA, but use what you feel comfortable with, and at your own risk.) Put a generous amount of AA on the clean pedestal, and goop it into the channel around the pedestal. Place the LED onto the pedestal in the same position as the original. Seat the LED into the AA. Rotate the LED back, and forth while pressing it down. Thread the reflector/lens part of the head onto the LED/bottom portion of the head and check for perfect centering of the LED. Adjust as necessary before the AA dries. You have less than 5 minutes, so work quickly. Before moving on, check to be sure that there is not continuity with the positive terminal of the LED and the head.
When the adhesive has completely cured, solder the wires to the LED. Use some paste flux and very thin solder to make the connections quickly. After testing the function of the light, mix another small batch of thermal adhesive and cover the leads. You could also use some Kapton tape on the back of the reflector to prevent a short to ground. put the light back together, and prepare to be amazed. The P2D that I upgraded with a WC tint Q5 had an average increase of 33% over the stock P4.
Good luck, and have fun!
datiLED
