Got mine today. Does your tail cap come off? Mine seems to be stuck or glued on. Strange that the button is a bit lower in profile than the previous gen yet it cannot tailstand.
Got mine today and I'm still doing some tests on it. My tail cap does not come off either and suspicion is that its glued on. Diagram in the manual shows battery insertion via unscrewing the head. So maybe its not meant to come off. Of note is that mine did not come with holster which I was a bit bummed. I'm assuming that Fenix is not providing a holster for them?
Initial test shows that its 5-39-87-159 lumens with an Eneloop. The turbo mode is very susceptible to a fully charged Eneloop to maintain its stated turbo brightness of 150 lumens. I'm still waiting for a 14500 battery to get fully charged. Glad I ordered a couple of Fenix 14500 batteries as my Keeppower and my EagleTac batteries are too fat. But further investigation shows that Fenix narrowed down the tube. Those two batteries slide with ease in the LD11. I also got one of Fenix new 1.5v rechargeable lithium ion batteries and though I was a little skeptical of them (they actually have a micro USB port right on the battery to charge), I am anxious to see how well the compare to an Eneloop and 14500.
Tint is similar to the HL50 headlamp which is neutral but with maybe a hint of green. Not so much that its an issue and you'd only notice it if comparing to something that I would consider a perfect neutral tint such as the HL50......but it is very close. And I'm sure it varies a little from unit to unit. I say I like the tint. I'd estimate around 5000k. Beam definitely tighter and smaller than HL50. Beam pattern is similar to any other XP-G2 light. [Edit: If anyone is familiar with the LD11, the new LD12 beam pattern pretty much looks identical now that I've had some time to play around with them.......just the the LD12 is neutral vs the cool white LD11]. No real rings present. There is an abrupt end at the spill. Beam pattern is very good in my opinion. Total diameter is the same as the LD11.
Some run time tests coming if I can figure out how to post a picture on CPF now that the latest free hosting site (Imgur) that I was using requires a login now. I may have to consult you guys on what to do there.
Edit: I have now charged my 14500 and this is what I get:
5-40-96-400 lumens. It edges my PD32, XPG2 just barely. So call this a little mini PD32 light. I really like this new LD12. I had some bad luck with previous LD12's once Fenix went over to the XP-G2 LED, or the Gen2 LD12's. I had two that would not regulate very well and did not perform like they should. So I was anxious to see how these new ones did. I felt pretty confident that there would be no problem because by utilizing an 4.20v battery, I knew the driver was totally new. This new LD12 has rock solid regulation from my initial observation looking at the light meter. I really like the light and I'm usually pretty picky. It's passed the tint test for me. I'm grateful that there is not 5 modes. I wish there was a holster. The switch is still kind of stiff like the new 2016 PD32. The light is a keeper for me. The final test is efficiency compared to other single AA, XP-G2 lights such as the LD11, EagleTac D25A, Nitecore MT10A and Jetbeam MK-I which have shown to be leaders in efficiency. Sorry I have no Zebralights to compare.
