SuperTorch said:
P1 is my next light. That size with very nice output is just rockin, how long is the battery life with the new brightness, I know it use to be 1:45 to 50%. Either way its my next light.
That 1.45 to 50% figure is not the rating with the Rechargables nor for typical primaries.. thats some funky Chinese ratings....
Here is the
chart for surefire battery SR123
You get two full hours of full brightness with another 30 minutes as it runs down.
I believe the P1 gives full regulation with the 3 volt primaries as stated on the chart.
The rechargables are 3.6 volts "actually 4.2 briefly upon initial startup" and the PI releases regulation "above 3.0 volts" and becomes directly driven from the battery... so you get an "even brighter" beam than with primaries due to the higher voltage and regulation being released.
Primary batterys will give that constant output for two hours "due to the regulation taking over", with another 30 min rundown time... but the rechargables will be brighter.. but will literally change bightness minute by minute until drained.
Often the rechargables will not have as much runtime since they push out more current with the higher voltage.. but its more glorious while it last!
If using rechargables.. make sure you get the
protected cells.. otherwise you may drain your battery below 2.4 volts where the lithium goes to the plates and you lose the capacity of your battery forever from then on.
Its true, the protected cells will leave you in total darkness once they hit thier critcal 3.0 volts, but at least your battery will live to run another day.
Just keep your backup handy.
The P1 has circuit protection that shuts the light off should you get the voltage down to 1.7 volts.. but by that time your recharable battery will have been ruin for the most part.
Also, the protected cells will prevent you from overcharging them above 4.2 volts which will give you perfect longevity like expected.
If you were able to charge higher "like in unprotected cells" you would get more capacity, but it would be short lived and you would drastically reduce the number of cycles left on the battery, thus shortening its life.
The cool thing about the P1 is it works perfect on primaries, yet it likes the higher voltage of the recharables too.
There are other lights out there that have the advantage of variable brightness, but its always at the expense of runtime. Efficiency is lost in their brightness circuits, so its nice to have a light that is
this bright, this small, with this runtime.
Many folks will admit that although its cool to have the dimmer features should you wish, they almost always run at full brightness!
