Monkeyboab
I had been considering modifying a light for work as the lights we use are really poor, dim and yellow incandecent output less than a norman MagD. So while i was thinking about the build for my own light which has now turned into a 400 lumen job my mate asked me to make his better so i decided to put a Seoul ssc into it.
The light uses a pr based buld so I built the Led onto the end of a Aluminium rod matching the diameter of the pr base. Mbirds came up with this idea in his modded fulton post. I used a seoul ssc from dx $5.80 and one of the 3v drivers that give 700ma(seen on Crenshaws mod) they work out about $2 each.
I cut grooves into the rod for the wires and arctic alumina'd the led onto the tip of the rod. I shaped a washer to fit to hold the bulb aginst the reflector like the shape of a pr base
Then I cut it off the rod
Then I soldered on the board and put it in light and focused and centered it, bit fiddly.
Done! Quite pleased with the outcome, this one's zoomed in slightly
I'll post the mod of my own light once I get the 6AA-2D adapter I need to run it, I cant wait.
Thanks to everyone on here for your threads, Im addicted now
Rob
Rob
