Hey,
I have a Fenix LD05 2xAAA light I've been generally pleased with, but a consequence of carrying it clipped in my front pants pocket is that over time the clip has become somewhat loose. (yes, perhaps that wasn't the... brightest... idea) I've stopped carrying it since in that fashion.
Externally, the angles all appear fine, though it has about 1-2mm of play laterally and will no longer stay clipped to thin objects as it used to.
I put as much force into twisting the end as I dared, but could not see any way to easily disassemble it or how the clip is attached.
My assumption, however incorrect, is that the clip is attached via a steel ring between the body and tailcap of the light, and to fix it I need to remove it, bend it a bit, and reassemble. I'm not sure if that's the case and Fenix just used a lot of LockTite, or if I'm entirely wrong.
Anyone have any ideas here? I've tried searching, but I haven't seen anything on actually disassembling the body of the LD05.
Thanks.
Thanks.
