KingGlamis
Banned
I have this cheap 3D LED light with 32 emitters (see pic below, the one on the left). It had decent light output but stopped working. It looks as though one of the LEDs may have shorted out on the backside of the circuit board. I see what looks like dirt or something between the + and - contacts of one LED, and when I look at that LED I can see a discolored spot inside of it that is clearly not normal. If I remember my electronics correctly it seems all 32 LEDs are arranged in parallel (all of them share a common + circuit and all share a common - circuit). And in a parallel circuit, if one LED blows, shouldn't the rest of them still work? Or are LEDs different than incan with respect to parallel and series circuits?
So my main question is how do I figure out what failed to cause the light to stop working? Is there an easy fix, for example running a jumper-wire across the contacts of the blown LED? And lastly, where would I look for possible upgrades to completely replace the 32 LED insert with something better, possible a single LED with a reflector (the reflector size would need to be 40-41mm outside diameter).
Thanks for any help. If you need pictures of the back side of the circuit board I will take them.
