Flashlight to Laser?????
Not sure what you are trying to ask,
if you diffuse a laser to make bigger spot & try to use it like a flashlight,
I can imagine it won't be very bright, as Laser output is very small if measured by lumens.
If you want to put a laser module in a light (diodes do not have buttons, modules can) you will probably need to heatsink it. Do some reading over at laserpointerforums.com. You will also need to remove the button and solder a wire across the connections, so it is always on when power is supplied.
