NonSenCe
actual and feasible possibilities to get one in production.. not completely scifi ideas. atleast in my mind
1. 4AA light with 3 or 4 modes or nitecore/itp/jetbeam style of ramping up. as long as it has under 5lm low mode for darkness. light should be 2aa long and two wide.
measurements should be in range of 21mm*35mm*150mm. used either 4 paraller for LOONG runtime at 120lm and under.
or 2p2s setup for decent voltage but double the runtime than current 2aa tubeshaped lights.
oval body shape is rather convinient to carry and hold. one can carry oval shaped object almost as easily in your pocket as the minimaglite style. aa size tube is on the "too thin to be comfortable" limit atleast in my hands.
i think 1 aa battery weighs about 30grams. fenix ld20 is said to be 55-60grams empty and 115g with 2 aa´s.
so making a "ld40" would not make it 230g light as you recude the other reflector, clickybutton and led etc from it. more like 190grams. about same as fenix tk11? still reasonable weight for medium size edc.
and then small brother for above:
2. 2AA light that is 1 aa long. (85-100mm i think) but double wide at around 35mm. again it would be easier to pocket carry in my mind than the longer 2aa lights. not as subtle as 1aa or 1 cr light but very close. in my mind i would be ready to sacrifice that small weight and size disadvantage very often for double the runtime or better brightness than 1aa. just look at your cellphone. it might be close to this size and do you think its inconvinient to carry?
then third..
3. a backpacker special. 3 mode twisty light.
1. under 5lm 2. 30lm 3 .120lm.
a oval shaped light like 4aa above but the light actually would only use 2aa. the other part of the lights body could be used as spare battery carrier. or water tight compartment for your matches, tinder etc.
extra option: in this it would be cool to be able to use the sparebatteries to light up a small 5mm (red) led for really long runtime. ability to get dim light even from depleted cells that cant run the high power led anymore. this way only would needs a twisty for medium and high mode.
i would like to have the spare batteries IN the light i am using not somewhere in my backpack etc.
whaddayathink?
then third..
whaddayathink?
