I hope I'm putting this in the correct forum as it pertains to running an SST-50 in direct drive on 3 NiMH's.
I *thought* this build would work.
New Mag 3 D host with deep reflector.
SST-50 on H22A heatsink machined to accept the SST emitter.
3 D size Accupower LSD batteries.
Direct drive.
After mounting the wired emitter on the heatsink I ran it on my power supply for a few minutes to make sure everything was happy. My supply only goes to 3 amps and it purred like a kitten there. Heatsink started getting hot, so I knew the emitter was dumping out heat into the heatsink.
Assuming that the the current would be somewhat higher on the batteries, but still safe, I soldered the wires to the modded switch, and install everything into the light, hit the switch, and the LED turns angry blue before I can turn the switch off.
Hit the switch again,....dead.
I don't know why I thought this would work. I guess because I've done this with several *I* bin P7's.
Anyway, don't try this at home. Direct driving an SST-5- from 3 D size NiMh's is not a good idea.
The good news is that this light modding week has not been a total loss. Last night I finished up a C2 Centurion running an SSR-50 DD off an AW 18650 (2600mah). McR27S reflector. No pill. Custom heatsink pressed into light body for star to mount to. It rocks the dock.
Direct drive.
