Sold/Expired FS:5000mAh 2x6AA Stylish ROP by FIVEMEGA
Alin10123
Atlanta, Ga.
This is a nice setup. I've got one myself and makes the ROP run for a LONG time!
Good luck with the sale.
fleegs
Indy
How long is the runtime?
Does this light come with everything to make it work and keep on working? When I get it I can just charge it and use it?
How does the brightness compare to a regular ROP?
What condition are the cells in?
What is a HS?
Is this splash resistent? Or would it immediately short if the bottom gets wet?
Thanks,
rob
Alin10123
Atlanta, Ga.
Brightness shouldn't be too much different. Although with this setup the voltage sag will be much less than with other cells. So in a way it'll be brighter.
The runtime will be twice as long as the regular ROP.
HS= heavy stippled.
I wouldn't splash the light. I wouldn't risk getting this light wet with the charging jack at the bottom of the light.
redbird
SW lower Mi USA
The light offered does not contain cells. You just put yours in,charged while the light is on the way and there you are. A nice long running light.
