Britelumens
Hi Guys,
I think most of us is familiar with the new CREE 4 die emitter. For those who have been waiting for a heat-sink specially custom made for the MC-E, here is one :thumbsup:
Here is a small run new heat-sink that made to fit the latest CREE MC-E emitter in a MAG D host ( Mag C later ). Due to the small size of the emitter, and to precisely fit them. Quite a amount of work is needed to mill out the little 2 pockets. The legs of the 4 dies sit inside the slot (not very clear from the photo). Wires can be neatly run to have a parallel wiring on the 4 emitters. 2S2P wiring is also possible if you are comfortable with soldering small items. But they are meant for parallel wiring for ease.
It has a slot beneath the heat-sink for drivers board too. The rim of the heat-sink is similar to the P7 ones hence you can use any 15mm opening reflectors.
A small revision of the design will be made with the small inner pocket that was meant for the heat-sink beneath the MC-E emitter remove. I realized it is not very significant in helping with the heat sinking. But rather making it more costly and hence not my intention as I would like to have them affordable to everyone.
( The inner slot should be the other way round if you look at the emitter beneath, however, it should not affect heatsinking as it would be cover with heat compound )
There is only 9 pieces for this limited protype CREE MC-E heat-sink run at the moment. Kindly indicate your interest in the next available number and made payment after.
Dependent on the interest, they may be made again. Hopefully able to bring down the cost with enough interest. At the moment, they are going for $19 each.
2S2P soldering
Placing into the pocket
Completion
Available CREE MC-E heat-sink
#1 SOLD
#2 SOLD
#3 SOLD
#4 SOLD
#5 SOLD
#6 Available
#7 Available
#8 Available
#9 Available
$19 each, Please add $5 shipping for each order. ( Good for 2 heat-sinks)
Registered mail please add $2.00. I'll be responsible for lost or undelivered mail should you decided to choose this option.
I'll not be responsible for lost mail shipping via regular airmail. Please allow 9 - 11 working days for it to arrive.
First to post " I'll take it, get it" follow by PP to info (at) britelumens. com. Thanks.
With regards,
Jo @ Britelumens
p/s: I would like to thank Sabrewolf for lending me the MC-E emitter to test fit the heat-sink. Thank you once again!
2S2P soldering
Completion
#1 SOLD
#2 SOLD
#3 SOLD
#4 SOLD
#5 SOLD
#6 Available
#7 Available
#8 Available
#9 Available
With regards,
Jo @ Britelumens
