Sold/Expired FS Emoli $16, A123 $14, some bulbs, NTCs, windows, chargers.
jimjones3630
Northern Nv.
FS A123 $18, some bulbs, NTCs, windows, chargers.
Left this here for diy interests. Everything here has long been sold.
I consider all these batteries used. Guaranteed not D.O.A.
Have taken apart Milwaukee battery packs, discharged at 0.2A and charged to capacity.
All within 10% capacity.
Emoli made in Canada. out of stock
IMR26700A Lithium Ion Batteries
Unlike Lithium Polymer batteries, these cells are very rugged. It is encased in a steel can similar to NiCAD/NiMH batteries.
Specs:
Dimension: 26mm diameter x 70mm length
Weight: Approximately 100g
Mfg Claimed Capacity: 2670mah
Nominal Voltage: 3.7 V
Charge Voltage: 4.2 V
Mfg's Max Continuous Discharge Rate: 20A
Max Tested Continuous Discharge Rate* 45A (15C)
* Not endorsed by Manufacturer.
Direct drive solutions include:
2C with 2x emoli with short switch and 2x AW cell extender run Philips 5761 with NTC, wa1111. 3C,2D with 2xemoli same bulbs above. C size mags will require more honing, larger ID than A123 cells.
3D, 4C with 3xemoli and NTC run Osram 64430, tungsram 56580. without NTC and 3xemoli run 64625, 62138, 64610. 64623 will run very yellow.
5D, 6C with 4xemoli run Osrams 64623, 64458, 50w IRC bulb or bulbs haven't used IRCs myself.
6D with extention, 5xemoli using a PWM run Osram 64458. without PWM 5 or 6 x emoli 64655 maybe with 6, 6 for sure with 64657.
Can charge with older Li-Io or Li-Po chargers.
By eliminating cobalt from the IMR26700 cell it is possible to produce a much larger cell, while providing exceptional safety characteristics. Further developments of the IMR26700 cell will provide fast charge capability, allowing cells to be fully charged in as little as 15 minutes.
Cell Type IMR26700 Manganese
Size 26.4mm diameter; 70mm length
Weight 100g
Capacity 3Ah
Standard Operating Voltage 4.2V - 2.5V
Energy Density 285Wh/l
Power Density 1500W/kg at 20 seconds
http://www.swift-tuning.com/EMOLI_26700A.pdf
A123
  • Nominal capacity: 2.3Ah
  • Nominal voltage 3.3v
  • Charge voltage 3.6v
  • Core cell weight: 70 grams
  • Internal impedance: (1kHz AC) 8 mΩ typical
  • Typical fast charge current: 10A to 3.6V CCCV
  • 70A continuous discharge
  • 120A, 10 sec pulse discharge
  • Cycle life at 10C discharge, 100% DOD: over 1,000 cycles
  • Power: Over 3000 W/kg and 5800 W/L
  • Safety: Inherently safer and environmentally friendly
  • Life: Superior calendar life, 10X cycle life vs. conventional Lithium ion
Mfg recommended use charger with A123 charging program. See link for list of smart chargers.
http://www.batteryspace.com/index.asp?PageAction=VIEWCATS&Category=1279
2C with 2xA123 with short switch and cell extender run Philips 5761, wa1111
3C,2D with 2xA123 same bulbs above
3D,4C with 3xA123 run Osram 64430, tungsram 56580, "Top Chinese" 64430.
4D, 5C & extention or 6C with 4xA123 run Osrams 64610, 64625, 64623, 62138
6D, with 5xA123 run Osram 64458.
6D with extention and 6xA123 using a PWM run 64458
www.A123systems.com
A123 cells are POSITIVE ground casings. Uses a nanophosphate positive electrode (cathode).
Cell Specifications:
Cell Type: ANR26650-M1
Model No. AS400059-001
Nominal operating Voltage 3.3V
Dimensions: 26mm x 66.5mm ht. including tabs, 65.15mm without tabs.
Cell weight 70g
Assembly Weight 72g including tabs
  • Long running constant out put, one of the flattest discharge curves of any batteries. Cells are rated 70Amp or 30C discharge continuous operation. (33C pulsed)
Discharge graphs: http://www.aircraft-world.com/prod_datasheets/hp/A123/A123.pdf
A123 $18 cell
Used cells comes with no warranty. Only guarantee not D.O.A. (not dead on arrival)
PM or email best way to contact.
some bulbs, ntcs, windows, chargers on hand. Inquires welcome.
regular borofloat 2"
2" UCL
3"x3.25mm boro
3"x6.3mm boro
3" glass
Dummy AA cut from solid copper
bulbs
1185
1111
Osram:
64610 50w
64625 100w
62138 100w
64655 250w
64458 90w
64430 35w
Tungsram 56580 35w
"Top Chinese" 64430 35w
Re: FS Emoli and A123 Batteries (((((((SALE)))))) Emoli $13, A123 $11
Jim, I'm potentially interested. I've been harvesting cells from packs... if I might ask, where do your cells come from and how new are they? Also, do you leave the cardboard jacket or shrinkwrap the cells? PM me if you'd rather not discuss here in the open, but please get back to me one way or the other as I'm interested!
Sorry if first post not clear, A123 and Emolis come from new Dewalt and Milwaukee paks. Do or did have some from lightly used rc pak. All are discharged 0.2A then charged to check capacity, and within 10% of listed spec. Given reports of 1500 cycles with A123 I still list these as used. All come with cardboard, I've used kapton tape instead of shrinkwrap with C size M@gs. If you would like them wraped or taped let me know.
jim
These A123 cells... are they the same size as 18650s?
18650s are 18mm diameter and 65mm long.
A123 are 26mm x 66.5mm ht. including tabs, cell weight 70g
A123 are longer but probable are about the same wt or less. 2 A123 in a flashlight is so light, I've mistakenly opened tailcap thinking need to put some batteries in it.
Jim
Jim
do you mean
"A123 are 26mm x 66.5mm ht. including tabs, cell weight 70g
Emoli are longer but probable are about the same wt or less. 2 A123 in a flashlight is so light, I've mistakenly opened tailcap thinking need to put some batteries in it.
If so Emoli are 100g per cell.
Emoli and A123 realy are the heat: :cool:
Both are safe, or safer than Li-ion with regards to fire.
I have lots of emoli cells, and they make great long runing powerfull hot wires.
Think of all the lamps you have wanted to run, but have been unable to beacuse of the 2C rule for li-ion.
With a big enough host, eg. maglite or similar you now can.
A123 cells I have no experience with, but I have read up alot, and these seem like the most abuasable cells I have read about. Mega high current drain capacity, run low or even flat and recharge no problems.
think of the same capacity and length as 18650, but 8 mm larger diameter, and infinatley more capable as safely delivering Amps buy the bucket load.
Both these types of cells are THE cells you want for a high capacity hotwires depending on your desired set up, and requirements.
Jim is a Great Guy to collaborate & do business with.
I cant belive that with 1,006 views these haven't all gone already? :thinking:
You guys dont know what your missing. :p
