jimjones3630
- 3D-cell pewter Maglite, used has some carrying marks and few minor scratches.
- Kiu socket, ceramic insulated, switch modified for reduced resistance.
- 3 xA123, 2300Mah batteries yield 9.9v nominal over driving Tungsram 56580 6v, 35w bulb to 70w, 7.5A, 2100tourch lumens out the window.
- Lithium Iron Phosphate, LiFePo4 a safer lithium chemistry does not readily burn.http://www.youtube.com/watch?v=A9ayuFBDrSg
- Boro lens for highest temperature reistance.
- Smooth Litho123 camless reflector fitted for Tungsram bulb, long throwing wide hot-spot feathering into spill beam.
- Direct drive, save money no regulation needed. About 30 min. runtime.
- Tailcap modified for least resistance using Northern Lights mod.
- http://www.candlepowerforums.com/vb/showthread.php?t=143345
A123 are positive ground casings. This light is Positive ground to take advantage of the original safety of the circuit design. http://candlepowerforums.com/vb/showpost.php?p=2128722&postcount=6
- Long running constant out put, one of the flattest discharge curves of any batteries. Cells are rated 70Amp or 30C discharge continuous operation. (33C pulsed)
- Typical RC chargers rated for A123 recharging: BC-6 http://www.rcaccessory.com/index.asp?PageAction=VIEWPROD&ProdID=241
Head, reflector, and Kiu socket surrounded in ceramic blanket material for thermal management. Space available to insulate batteries if desired.
- Or Dual power option with 3xEMOLI = 11.1v nominal, 12.6v fresh charge run any 12v bulb direct drive: 50w 64610, 100w 64625, 62138 100w, 64623 100w.
- With 64625 over 3,900 lumens
- If have older 64430 bulbs, they have instant flash on 3xA123, but do not flash with NTC which I will supply upon request.
This light produces over 3,300bulb lumens and is lighter weight than 2D with Ni Mh batteries.
Can also use: 1185 at 9.9vbat. produces 572torch lumens ( 879 bulb lumens) LOLA bulb
Emoli
Cell Type IMR26700 Manganese
Size 26.4mm diameter; 70mm length
Weight 100g
Capacity 3Ah (26700mah)
Standard Operating Voltage 4.2V - 2.5V
Energy Density 285Wh/l
Power Density 1500W/kg at 20 seconds
Specs:
Dimension: 26mm diameter x 70mm length
Weight: Approximately 100g
Mfg Claimed Capacity: 2900mah(26700mah)
Nominal Voltage: 3.7 V
Charge Voltage: 4.2 V
Mfg's Max Continuous Discharge Rate: 20A
Max Tested Continuous Discharge Rate* : 45A (15C)
* Not endorsed by Manufacturer.
This custom modified light is made with used parts. Modified components are not in original condition. Buyer assumes all risks and responsibility to use this light safely. Only warranty is not DOA. Making this purchase buyer certifies they are at least 18 years of age and assume all risks and responsibility to use this light safely and accepts the light and parts in an "as is" condition.
$225 includes One bulb & 3 A123 cells, if have older 64430 bulbs which have instant flashed on 3x A123. I will supply NTC tailcap mod.upon request, shipping CONUS. 1st I'll take it gets it, time stamp rules. will post in other forums.
3 Emoli cells available for sale.
