ARC mania
I am putting up one of the two existing protype Mega Micro flashlights for sale in order to raise funds for a future project. A manual lathe was used in machining so, a sort of custom light. The price is a bit steep. One thing for sure is that you will get a one of a kind light in perfect working order. Currently the LED used is a Diamond Dragon driven at 1.5 amps from a single CR123 (RCR123 rated at 3.7 volts can not be used) battery. For its size, its extremely bright! It eats up flashlights out of its class. Asking price is $800.00 which covers PP fees and express mail shipping anywhere in the world. I will let the buyer choose between a P7 D bin in brightness LED or the Diamond dragon LED. Both will be driven at the same current. If you are interested in purchasing this light, send me a PM. Here are the specs:
SSC P7 LED bin: DSXPJ/ Osram Diamond Drangon LED NY in brightness (330 to 390 lumens)
full bin number is unknown only brightness. Tint is similar to "V0".
SchottB270 mineral glass with AR coating.
Aluminum orange peel reflector.
T6061 Aircraft aluminum
Silicone o-ring
Twisty tailcap switch
Run time 24 minutes
1 x CR123 powered
ARC mania
Silicone o-ring
Run time 24 minutes
1 x CR123 powered
ARC mania
