Sold/Expired FS: Not quite my whole collection...but close to it. (Closed)
DFiorentino
MD
:sigh:
A3, Blue/Black swirl/marble anodize (by trivergata) (dark blue-hard to photo correctly), U4SY LuxV (Royal Blue), DB750, 2x123, standard flat tailcap, McE2S 2-stage switch…$205 w/light engine; $175 w/o light engine shipped USPS Priority
TnC-SF, polished nickel plating (by modamag), Al (nickel plated) bezel, 27mm head, your choice of McR27-XR/S reflector, 1x18500 tube, recessed tailcap, McClicky switch, no light engine…$175(light engine can be built at an additional cost with parts I have on hand only; PM me for details) shipped USPS Priority
A2, TiN coated (yes, it is Al), Al (nickel plated) smooth bezel, 1x123, standard tailcap, McClicky switch, F6FA LuxIII (Amber), FluPIC…$205 shipped USPS Priority
A2, Red/Gold (by trivergata), standard bezel, TB custom E-series 1x123 Kroll tube, Kroll switch, no light engine…$165 shipped USPS Priority (light engine can be built at an additional cost with parts I have on hand only; PM me for details)
- HA natural DSpeck custom double headed tube, 1x123 E-series threads on one end – CMG white LED 1AA head on the other…$35 shipped USPS First Class
- Surefire N1 bulb, new…$15 shipped USPS First Class
- Surefire N1 bulb, opened, tested for <1 minute…$10 shipped USPS First Class
* [Take both above N1's for $15 shipped USPS First Class]
Arc LSH, polished and gold plated (by modamag), HOST ONLY, includes B270 glass lens, ARC retaining ring, CR123 and CR2 twisty tails (sold as set only), CR2 o-ring is not the correct size, but the CR123 is correct, some plating didn't make it all the way into the threads as seen in the pic above...$160 shipped USPS Priority (Can include an Arc FluPIC board for an additional $25) [SOLD]
Arc LSH, Red/Violet (by trivergata), B270 lens, McR-18, SSC P4 USW0H mounted on an E-Screw, Arc FluPIC v2.2 (so R123's only), Kroll tail, emitter is just a hair off center as seen in pic above (note: Kroll switches can be quirky with fluPIC boards. Due to the spring mechanism inside, you can sometimes get a "double click" action with a hard fast single click intention.)...$175 shipped USPS Priority [SOLD]
Arc LSH, turned smooth (by me), polished and nickel plated (by modamag), HOST ONLY, includes B270 glass lens, ARC retaining ring, CR123 and CR2 twisty tails (sold as set only), CR2 o-ring is not the correct size, but the CR123 is correct,some plating didn't make it all the way into the threads as seen in the pic above...$160 shipped USPS Priority(Can include an Arc FluPIC board for an additional $25) [SOLD]
McLux Ti XR27-C, bead blasted, diamond coated (by modamag), Q4 WC emitter, 150/850 Piglet (by Goldserve)…$950 shipped USPS Priority [SOLD]
McLux Ti PD-S, bead blasted, AlTiN coated (by modamag) (piston was not bead blasted), stock SSC P4 (my guess would be a cool SX0 or SYN), regular non-mizer version, currently has no trit installed, so take your pick of color (green, orange, ice blue, red, and some sort of deep blue/purple)…$650 (or I'll leave it empty to install your own trit…$630) shipped USPS Priority [SOLD]
McLux Ti XR19-PD, bead blasted, TiCN coated (by modamag), stock XR-R (my guess would be a WG), regular non-mizer version, one of the clip screws opening were stripped (or my bit sucks) so the light was platted as a whole (light, clip, clip screws), currently has no trit installed, so take your pick of color (green, orange, ice blue, red, and some sort of deep blue/purple)…$565 (or I'll leave it empty to install your own trit…$550) shipped USPS Priority [SOLD]
TnC custom, orange/black splash anodize, MJ design #13, X4T LuxV…$250 shipped USPS Priority [SOLD]
A3, rubberized OD, WW0T LuxV, DB917, 2x123, standard tailcap, McE2S 2-stage switch, TB Ti bezel…$350 shipped USPS Priority [SOLD]
A19, polished nickel plating (by modamag), Al (nickel plated) smooth bezel, TB custom E-series 1x123 Kroll tube, Kroll switch, no light engine…$210 (light engine can be built at an additional cost with parts I have on hand only; PM me for details) shipped USPS Priority [SOLD]
Black (motor oil) EN McClicky Mule no light engine…$135 (light engine can be built at an additional cost with parts I have on hand only; PM me for details) shipped USPS Priority [SOLD]
Custom Ti anodized (by Leni Fried), TB "A18" head, McGizmo 1x123, McTC tailcap and bezel, McR-18 reflector, McClicky switch, no light engine…$510 (light engine can be built at an additional cost with parts I have on hand only; PM me for details) shipped USPS Priority [SOLD]
Ti McClicky pack, currently has a GITD (green) switch cover installed (stock switch cover included)…$175 shipped USPS First Class[SOLD]
Surefire 3DL IR illuminator…$50 shipped USPS First Class [SOLD]
TnC HA-Nat Al 38mm head, E-series, standard bezel ring and lens included…$80 shipped USPS First Class [SOLD]
TB Ti A3 (38mm) bezel…$140 shipped USPS First Class [SOLD]
Jewel of California, gold plated elephant FM3H fat body, 10W WA HID, 3x18650 carrier (batteries not included)...$500 shipped USPS Priority [SOLD]
Surefire 12ZM (3" head), anodize is faded on head (not as much as the photo seems to show), nicks (more like scratches) here and there but nothing deep, reflector is in good shape, a user - not abused, no bulb or LED tower included...$180 shipped USPS Priority (I paid WAY more than this, more than I probably should have :shakehead )
[SOLD]
Supernova (Maxabeam clone), includes everything as received (battery belt, charger, yellow filter, instructions, case), yellow filter has one tab that was broken, but repaired and functions fine (previous owner), can photo later if so desired ...$375 shipped USPS Parcel Post (I think) [SOLD]
- Mil-Spec black HA (by Mirage Man) 3D Mag, quad-bored, FM 12AA-3D adapter included, 12 Sanyo Eneloops included, all stock Mag components included, used with some scratches on the head and tail, 7/10 condition...$80 shipped USPS First Class [SOLD]
- PQS-CU, copper quad sink for MagC (for Luxeons with double 'D' slug)...$15 shipped USPS First Class
* LEDs...
LuxI
: 9x LD emitters, unknown bin, warm white (yellowish with yellow/green corona), new…$1.50 each/$9 for all shipped USPS First Class 20x LD emitters, unknown bin, cool white (bluish/white with yellowish corona), new…$1.50 each/$20 for all shipped USPS First Class 1x RX0H star, tested on bench PS <5 minutes, never installed…$2.50 shipped USPS First Class 2x SX0H stars, tested on bench PS <5 minutes, never installed…$4.50 for both shipped USPS First Class 3x SW0H stars, new…$3 each/$7.50 for all shipped USPS First Class
LuxIII
: 3x SY0K stars, used…$3.50 for all shipped USPS First Class 4x TX1K stars, new…$3 each/$9.50 for all shipped USPS First Class 2x TX0H stars, 1 new, 1 tested on bench PS <5 minutes, never installed…$6 for both shipped USPS First Class 3x TX0H emitters, 2 new, 1 tested on bench PS <5 minutes, never installed…$9 for all shipped USPS First Class 1x UX1L emitter, new…$4 shipped USPS First Class
K2
: 12x UYAN emitters, new…$2 each/$20 for all shipped USPS First Class
LuxV
: 1x VY0T star, tested on bench PS <5 minutes, never installed…$7 shipped USPS First Class 5x VY0S emitters, 4 new, 1 tested on bench PS <5 minutes, never installed…$10 each/$45 for all shipped USPS First Class
* [Take all of the above LEDs for $50 shipped USPS First Class] [SOLD]
- Surefire MN15 bulb, removed from outer packing but still in sealed inner plastic, new…$23 shipped USPS First Class [SOLD]
- 2x Carley H1499 (from Litho123), 1 new leads untrimmed, 1 used for <10 minutes leads trimmed…$17 for both shipped USPS First Class [SOLD]
- 2x WA1274, new…$10 for both shipped USPS First Class [WITHDRAWN]
- 2x WA1111, new…$15 for both shipped USPS First Class [SOLD]
- 6x AW 17500 , cycled once…$7 each/$36 for all shipped USPS First Class [SOLD]
- 28x 2-cell Mag bulbs, most brand new, a couple may have seconds of use…$15 for all shipped USPS First Class - 20x 3-cell Mag bulbs, most brand new, a couple may have seconds of use…$10 for all shipped USPS First Class - 3x 4-cell Mag bulbs, most brand new, one may have seconds of use…$2 for all shipped USPS First Class
* [Take all of the above Mag bulbs for $12 shipped USPS First Class] [SOLD]
All prices include stated shipping for domestic USA. First class shipping items can be upgraded to Priority upon request for an additional $5. Insurance can be added at actual cost. Signature confirmation can be added for $1. International orders please add $15 to listed prices (sorry, I didn't realize international priority rates were so outrageous).
"I'll take it" disclaimer...
First UNCONDITIONAL POST of "I'll take it" or "I'll take [insert item(s)]" wins. No if, ands or buts. Questions and PMs are welcome, but do not guarantee a sale. I do, however, reserve the right to make any final decisions regarding my sales (whatever that may be).
Paypal only for international orders.
Paypal prefered for domestic orders, but money orders will be allowed.
Payments must clear, Paypal or MO before shipping.
* Please include your CPF username and order in the note with your Paypal payment. *
Paypal address:
-DF
Re: FS: Not quite my whole collection...but close to it.
:eek: and this is not even your entire collection?!? Sweet lights you got. Good luck
I will take the 2x Carley H1499 and the 2x WA1111.
Since they can be sent together, can I get a small shipping discount?
I will send a cash PayPal as soon as I get a total.
Thank you and good luck with your sale.
:takeit: backup - TB Ti A3 (38mm) bezel…$140 shipped USPS First Class [On Hold]
D,
Goodluck with your sale! I hope the best for you! Take care...
jag
I'll back up the batteries in the unlikely event....so on and so forth...
:takeit: if condition is up to snuff.
PM's sent and replied.
-DF
I'd be back up for the Ti McClicky pack.
Damien, I'll take the MN15. PayPal incoming.
I'll take it :
For 630$ with no trit.
Is it rechargable compatible ?
What is the diference between Ti PD-S and a McLux Ti XR19-PD ?
What does SXO or SYN means ?
