nailbender
I thought that I would give you all a choice and add a Tri P7 to the already offered MC-E
Triple MC-E (4WT-A2-0000-000M03 bin) Rated @ 490 lumen @350mah
Led's run at max current of 2.8amps
Individual Leds wired parallel with the string wired in series
Silver Mag Host approximately 1d size
Grooved handle, boring and machining by Will Quiles
Perfect tri - quad sink
Thick UCL Glass
Ledil Boom SS Narrow Beam reflectors
Monetary switch with mod for flat nosed batteries
Tail cap modded for use with 4 X 14670 battery holder
Regulated current by the new Hipflex by Taskled set at 2.8 amps and is between 90 to 95% efficient
uses new UI-UNI dimming firmware
This light is super bright with lots of spill.
I use a house to test out lights that is about 200 to 225 yards away, and I have many lights that light up this house
but this light does that plus the houses on each side.
Price is $290 Shipped Conus Int. quoted
Thanks
Dave
I am adding a Tri P7 To go along with the above offered Tri MC-E
Triple SSC Seoul P7 (DSXOJ bin) Rated @ 800 to 900 lumen @2.8 amps per die
Led's are wired in series and are Direct Driven
Copper Mag host with Grooved Handle & Finned Head
Host Machined by Mack Tri Bored to accomadate a FM 3 X 17670 holder ( not furnished) Can be purchased with light
Modified PES universal sink from the sandwich shoppe
IMS smooth reflectors Replaced with Ledil Boom S narrow beam reflectors for SSC P7
Monetary switch wired with Mil Spec Teflon Wire
Tail cap modded for use with 3 X 17670 battery holder
Latest d2Flex Driver ( UIP: 5 level dimming, flashlight use optimized )
Grooved Handle & Finned Head By Mack
Wanted more mass for heat sink so I added 5 pennies shows thermal compound under sink
Price is $325 Shipped Conus Int. quoted
Paypal cash or CC add 3% PM for addy First I will take it gets it.
Thanks
Dave
Thick UCL Glass
- UI-uni Firmware:
- Unification of UIF/UIP firmware with the UIB2 firmware.
- 3 user configurable voltage trip points to set independent Medium, Low warning levels and Cutoff.
- If an optional 3mm or 5mm status LED is connected, the user can configure the status LED to warn when the voltage reaches Medium (status LED lights constant) or Low (status LED flashes).
- Temperature monitoring of driver board. If closely coupled with the light's body, it can be user configured to force the current output to reduce. Optional trip points of 50, 60, 70, 80, 90C or off.
- UIB2: Bike optimized, Choice of 2 level (duomode) or 5 level (multimode) operating modes.
- UIF: 8 level dimming, fixed lighting use optimized..
- UIP: 5 level dimming, flashlight use optimized. .
- User selectable optional Force level (the level that the light will always turn back on).
- Optional superlock that requires multiple clicks to turn the light on - prevents friends turning your light on accidentally.
- UIB2: User selectable Strobe mode or Constant mode for day/dusk or night use
Thanks
Dave
Thanks
Dave
