Stupid little story time:
Disclaimer, never "Flash Amp" or short curcuit a high energy battery, especially a lithium one.
Voltage vrses Current, to get idea of level of capacity.
There is always questions about how to read capacity VIA reading the voltage, well you can and you can't, here is a story about how we learned some of this the hard way.
Somewhat Long ago in a far off land . . .
Highly dependant on batteries on the job, but using some 20-30 of them Per job, we had many batteries (mostly alakline) that were used for less than 20% of thier total capacity. We couldnt throw them out (cheapskate) and there were too many to use in other devices that were not important.
So we went to RadioShack (now known as the Cell store
) and got a simple battery tester. it had an analog meter, little needle in it that moves from green to yellow to red.
we started testing everything , and tossing out batteries that were not in the green.
went back to the job and got BURNED royally, lots of the batteries that tested high green DIED early
. The test was simply a voltage meter with colors.
Sooo
When we came back from that job, we used this tester again, and threw out all the batteries did not read Way high in the green. Re-calibrating this minimum Voltage we were going to allow. now they had to be good they all read very high voltages.
Went back to the job and got burned again, few of the batteries that tested high, were dead before the job was over
soo
Knowing that i could have put the batteries under a Load , and tested them better, i tested the batteries by "Flash Amps" using a newly purchaced 10A ampmeter. ONLY ALAKALINES and only the small ones, and only for a short time.
I assaulted each of the used batteries by shorting the ammeter across them, and using only the ones that pumped out major amperage.
Went back to the job again, and every battery that had good output amperage during this harsh amp testing , survived the job just fine.
But
this was still a royal pain in the butt , not having a quick easy simple (anyone can do it) method for sorting out the batteries, requiring the meter. It was harsh on the batteries, and took a lot of power for each test, also it couldn't be used for other various volitile chemistries.
SO
i took apart the (stupid) radioshack meter, and put a simple 10ohm 10W resister across the contact points for the battery. this would read the (red green yellow) voltage thing while the battery had a load on it. It would also completly drain the battery if left in it , probably a good reason why they didnt sell it that way.
Now
my stupid easy meter had a load, i recalibrated where we thought red yellow and green actually were, and this worked great for long and long times. the small load added to the device would read the voltage under a load , instead of the no-load voltage. Job after job the batteries tested with the load voltage , would last long enough to survive the job.
now (of course) we use more rechargable batteries, but i never forgot how Wrong the simple voltage only reading was , for displaying "Capacity" especially and specifically for alkalines and carbon types.
the battery checker lived a long and happy life (almost happily ever after)
voltage this voltage that, but chemicals in the battery (IMO) are more "Power" than voltage and amperage, its all about the WATTS (remember that when looking at specs/graphs). Sure the cell has been tuned and certian chemical reactions have a certian reaction voltage potential, but electricity stuff is more about total Power than just the voltage. if you want to know how usefull the chemicals are in a battery, read the Watts
We try and put electrical characteristics paremeters on Chemical reactions that output electricity , but really its about the chemicals themselves that were tyring to test.
by putting a light load on a battery test, you can tell a lot more about the battery.
