G2 Pocket clip needed
hawkchucker
OK I spend a ton of time at work using the G2L and love it. Unfortunatly I would love to find a pocket clip to make it easier to carry in my work jump suit. I have looked everywear and have not found anythign.
Can anyone help? I am looking for a clip that can just slip over the body not screw to it.
The Nova Tac pocket clip works quite well. I prefer the new flat style & you really have to tighten it, but it fits the bill nicely.
Here, at last is a picture of the clip on a NovaTac!
Here is it locked out and switched on:
Wow, it actually worked. I finally posted a picture.
BTW, even if the clip doesn't look secure, it is. It has hung on a ruck sack for many miles without falling off.
I got to thinking that I should have mentioned that I got the NT clip to work only when I used a Leef tailcap wherupon I could fully screw down the tailcap. I had tried it on the standard LOTC and it was too loose. How did you get it to seat securely?
I'm ready to order a couple of the clips but I'm concern by your pictures: clip on top of a glow ring ?
any way to measure the inner diameter ?
Thanks
I checked on my G2 : we need a 22mm (inner diameter) pocket clip.
The Novatac is 25mm (outer) but what about the pocket clip ?
Anybody with a 120 and a ruler close by ?
am looking for a clip for my stock G2 as well, so instead of posting a fresh thread, i thought i'd just revive it, so guys, does the NT clip work on a stock G2 with LOTC?
I lost my first G2 cos it wasnt clipped in my bag and it rolled out and went into someone else's hand dammit :(
Like the others say, the Novatac clip will work on a G2 or 6P, but the diameter of the clip is a little bit too big. You will have to use an extra o-ring or two to get it snug with the tailcap. I ended up cutting out a rubber gasket to fit between the tailcap and body. It works almost like a grip ring and makes the tailcap snug on the clip. Works great. I wish I had a picture to post.
Kinda odd looking, a clip with Solarforce stamped on it, on a Surefire light :D
well, thanks for the help everyone, i've ordered some solarforce clips and am waiting for them to arrive.
I have one on my 6P GM and it matches/fits well. But it doesn't have much tension and I use it for convenient pocket access rather than a serious carry option. It's not nearly as strong as the CL1H/DBS clip. I feel safe jogging but not running with it clipped to my pocket.
But for the price it's a good deal.
thanks for the tip, i ordered 3 clips, 1 for my G2 and the others for my Solarforce hosts.
