G2 + SureFire KR1-BK Conversion Kit + CR123A (x 3)?
adamlau
Los Angeles
Anyone know if the extended Nitrolon body of the kit will allow the G2 to hold three CR123A cells, properly contacted at the lamp and tailcap w/o modification?
The G2 extension tube is longer than the A19, too much longer to make any contact with 3XCR123 batteries. I have the 6P version of the conversion kit.
Bill
You could try a charging spacer from lighthound - those have 1/2 cell length and should roughly be the right length. It would be necessary to wrap it in tape to avoid contact with the body of the light.
I have that setup using a cut down 123 dummy from Lighthound.
You will need to use aprox 2/3 of the dummy battery. Be sure to measure.
I cut mine with a dremel cut off wheel, then slap in a 9 volt l/a.
It feels great to me with the extra length.
I have 3 of them actually different colors of course.
I recommend replacing the lens with a ucl from lighthound as well as the 9 volt l/a's put out more heat.
Hog
