so i just started to get all the pieces together for my dive light, my driver from George came yesterday so i got to get that all wired up ...
this is a thing of beauty .... and it pumps out some serious power to the SST chip..
with some emails back and forth to george i got it all together..he is at Task Led .com I still need to get it all put together in the light engine .. Here is a shot of the SST in the reflector from Deal Extrm
i have the led Mounted into the lens , and I use aluminum Tape HVAC , to diffuse heat off of the Led , I am also going to add more heat sink stuff after i get the acrylic lens cut , and it Mounted into the light head ..
front shot of the reflector ...
and a front shot of the Light head , the light head is a Black sched 80 drain fitting from Home Depot.. and its a perfect fit !!
More pics to follow as I build this beast of a dive light
I am diving here in Puget sound , Washington state , so our water temps here ar 52 deg.. once this head gets in the water It pretty much cools the heat coming off the Led to Zero.. The cold is absorbed through the PVC and then transfers to the Light engine .. like i said more pics soon for all to see ...
