kurni
I'm a LED fanatic; started from the moment when L1D CE hit Australia. The light is white, I was over the moon.
But seeing things under this awesome white LED is rather "strange", I can't put my finger on it. Only white wall looks perfect.
I then obtained Dereelight Q2 5A; things looked good but I can't get over the touch of pink.
Unfortunately I read McGizmo's thread about CRI; now I have more ideas about how to spend money that I don't have. I'm considering mixing two SSC neutral white and one U2SWOH but I will still have problem with 480nm-490nm blue-green deficiency.
I found an easy and cheap way to get good colour rendition. It is too warm for me but the colours look right. I'm going to use it for some time and see if I like it.
I popped a P60 in my C2.
Rendition problem is solved but here comes the temperature problem.
Am I alone? Anybody on the border? What do you do to address this problem? My C2 needs a proper gut; a bright one. It doesn't have to throw because I usually use FM34 anyway.
Thanks in advance,
Kurni
Thanks in advance,
Kurni
