julesb said:Almost indistinguishable except for the different knurling and branding. Even the manual is pretty well the same. I regret buying it a little now, as it adds nothing new to my collection.
swxb12 said:Regarding the Dex/Jetbeam with 1xAA...
Are we talking about over 80 lumens with a 14500? TIA
BugOutGear_USA said:What are you getting out of it with standard AA batteries? Is it much brighter with the 14500?
Flavio
derfyled said:My MKIIx running on 14500 is WAY brighter than my l2d ce and is close to my seoul-mod HDS. If you are only looking for brightness, you can't go wrong with the MKIIx on 14500, it's a wall of light with a very good hotspot for an OP reflector. Never leave it on high on a table for more than 8-10 minutes, it gets VERY hot, can almost burn your finger.
cmacclel said:You should never run a light designed for 1.5v cells unattended on a table with a Li-Ion. Your probably pushing well over an amp to the LED with barely and heatsinking.
Mac
derfyled said:The MKIIx supports any AA-size battery from 0.7V-4.2V
cmacclel said:If a light can burn your fingers after 8 minutes then there definetly a problem
Mac
true, but...T4R06 said:to all:
jetbeam MKIIX w/ 14500 100% mode is over 150lms
brighter than any fenix lights
