Thanks so much for all of the replies so far - wow, a wealth of information already.
Whoa lots of variety to research and try here, awesome info!
MD2 (primarily to run on 1x 18650) then MD3 (primarily to run on 2x AA) for first couple of hosts.
Thank you for the follow-up - excellent info on how to build out a tight Malkoff collection from the ground up.
Would love a modified Malkoff (MD2 or MDC) as my first, but should probably humble myself and pick a stock light to start. Might still be a Malkoff though..
I'd buy an M361 in any flavor with an MD2 host and tricap. It would have saved me from buying so many other more expensive lights.
I learned a lot from HDS lights but if I had to start again I'd skip over them and start with a MD2/MD3/MD4 and go crazy with Dropins.
Thank you both, and more Malkoff love. I'm sensing a pattern here...
I think I'd re-start my from-ground-zero collection with an Oveready BOSS 70... A HCRI HDS 18650 Clicky. HDS HCRI Rotary in 123. Add in a neutral Hound Dog 18650. Scour the WTS for the V4 Wildcat I just got. A Malkoff N-LLL Module or three. Empty MD2 w/hi low ring for said dropins. SF 6P host. Okluma DC1, Tana E1e Triple build. McG Mule. A Pak-lite or two. I'm sure I could think of a few more.
Yep expected to see a Boss 70 eventually, and more HDS. Those seem like strong picks for keeping stock vs Malkoff and others really being great for modding.
Makes sense, for the higher price, you'd expect to be able to run Boss and HDS stock (and have more options available). Love the sturdy and customizable build qualtiy these seem to offer.
I would start with One-Off GTvn with Luminus CFT-90 LED.
Wow that's a stunning purple, and what a light. I'm guessing you prioritize having a workhorse first over edc (well, your forum name is search and rescue after all..)
Next light purchase after the headlight would be a Nitecore Tip 2. That covers my edc needs and some lower levels. Then a Lucy Lux pro solar inflatable lantern would be next. It could charge the tip 2 in the field. Then I'd want something bright. A Nitecore TM06s will do. 4000 lumens for an hour is enough (doesn't dim down after seconds like most lights). These lights wouldn't be all I get, but it would be a good start.
Thank you for the follow-up, and I like how you've thought about your progression and using the solar lantern as a means to charge the Tip 2 if necessary.
Lanterns don't seem as discussed much but seem to offer high utility in certain situations.
Also... Where's the Fenix?! Mostly Nitecore so far haha
Welcome to the forum
And I agree that learning to swap LEDs can transform a light from something I choose not to use,
to a light that brings a smile to my face.
One of the variables you will want to consider, is the size of the light, and size of the battery it uses.
Thank you for the warm welcome and follow-up! (and apologies to CPF for asking where to buy, will go back and read rules more closely)
Those size pics really highlight how different form factors can be for given battery sizes.
Also neat to see how they can reflect the design philosophies of the companies behind them.
Really appreciate the thoughtul responses from everyone so far. This is hugely helpful for a new person just getting started.
