Good evening All,
I need to present a little background, pics, and calculations here before getting to the real question (please bear with me).
Background: So I picked up an aftermarket fairing for a small, dual sport motorcycle, that I have been wanting to try. It came with two 90mm Hella headlights (one hi and one low beam), powered with 65w Phillips halogens, with a H9 base (#'s on the bulb were H9/d52 and 12382)... The longer lamp on the left (Viewed from the back) is the low beam, with a metal block on the lower half, which reflects the light to the top, and then downward to the road (hence - low beam)... The Hi beam (right - from the back) is just a standard round reflector..
The fairing manufacturer is currently using lamps with Cyclops LED bulbs(@ $70/each...ouch!) They give him the lowest warranty rate but, they are in different lamps than my older fairing... He says that motorcycle applications need a bulb that withstands vibration better than for passenger cars... He told me to try the Phillips LED's for $40 for 2, as it was my own project LOL.
[/IMG]
[/IMG]
Calculations: The bike itself has only a 100-110W AC generator. I am told once you change that to DC (using a rectifier), you get about 50% (which is a little conservative).... So, with Virgil's help I have ordered a tail light bulb that draws only 2.3W, leaving 50W left for both headlights.
Finally, the question: Can someone give me direction on what brand, product line, or style, of H9 based LED's that work well as halogen replacements, and will withstand vibration???
They probably won't be 200% more, as I am limited to 25W/each... My initial research told me it is hard to figure some of the LED replacements wattage, but with enough digging it can be found!. I can do the research.... Some experienced direction would be greatly appreciated!!
Thanks in advance!!
Keith
Thanks in advance!!
Keith
