LED Zeppelin
Hardware:
- HA black Mag 6C
- Sleeved for (4) 18650 w/ dummy spacer or (5) w/ deep tailcap
- MC-E M WD
- Shark Buck 3A/ recoded Remora, SharkSink C
- modified Britelumens MC-E Mag C heatsink
- Kai MOP reflector
- UCL
Specs:
- Vf of MC-E = 3.5V @ 2.8A
- Recoded Remora w/ output levels of ~ 1.5%, 18%, 100%, (40mA, 540 mA, 2.93A measured). Original Remora levels were ~ 15%, 35%, and 100%. Timing of mode advance mimicks the GDuP, and operation is virtually identical.
- Connected to my power supply, the light draws 0.02, 0.15, and 1.21A @ 14.8V (4 X 18650) on the respective levels. At 18.5V (5 X 18650), the light draws 0.02, 0.12, and .97A.
Notes:
- The sink is secured in the tube with a set screw which is accessed by passing the wrench through the tube to the far side, like the Mag switch.
- The head bottoms out and tightens on the tube just as it comes into focus.
- I had issues with the contact bounce of the switch unintentionally advancing the level. I disassembled the switch and increased the spring pressures which nearly eliminated the problem. Occasionally the light will advance to lo from hi, but it is vastly improved and acceptable.
Some build pics:
Some beamshots vs. an Arcmania Ostar SF-V, the only other single LED Remora light I have on hand. The SF-V has 4 levels, and these were shot at levels 1, 2, and hi. Notice how the new Remora levels are much wider spaced, and much lower on lo.
Indoor beamshot camera settings are all the same: ISO 200, white balance sunshine, F4, 1/8 sec.
Shot progression from lo, med, hi, to outdoors @ F4, 3 sec.
