hardinge c30a cut knurler- updated with pics
gt40
bainbridge island
Anyone heard of these:
HARDINGE C30A CUT-TYPE KNURLING TOOL 1" SHANK
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItemVersion&item=360270538031&view=all&tid=0
Looks beefy and I wanted to try a cut knurler. The fancy ifanger, quicke and zeus looked really nice but the price was scary. They all seem to work similar. I will post some pics after it comes. It uses 3/4 x 1/4 x 1/4 straight knurls. Any suggestions on cost effective source for additional ones?
Re: just won a hardinge c30a cut knurler...
Good catch :thumbsup:
See page 6 for info: http://www.hardinge.com/usr/PDF/tooling/1318.PDF
Knurlcraft probably supplies more knurls than anyone else in the world: http://er-tooling.com/Eaglerock/cutknurling.html
I looked on eBay for quite a while for a cut knurl tool, but ended up buying the Eagle Rock K1-44 form knurling tool, 0-2" capacity (Enco had it on sale for about $150). It's the best knurling tool I've ever used, and easy to set up.
Link no worky...... I have an extra LH Cut knurler made my Dorian that I bought and never used. If anyone's interested PM me. Please let us know how the knurler works for you. I have a Quick/Zeuss adjustable one myself and it's still almost impossible to get repeatable results. I still find the knurling tool pushes the work away so I get deeper knurling at the ends :(
Mac
Maybe we can persuade Fred ( PhotonFanatic ) to give us some pointers.
I think he has mastered Cut Knurling.
Personally I find the knurling presses to be very non repeatable and frustrating, especially when knurling Ti after many hours of work ....only to do a poor knurl that ruins the look of the part.
Hate it.
here is a pic from the ad:
I will post more after I receive it...
I picked up the knurler and it is in good condition except someone stuck 5/8" knurls on it. On the link precisionworks posted, the holder is supplied standard with two “cut-type” knurls (Part Number: ST-0010901-D). The
knurls have a
34" (19.05mm) OD, a 14" (6.35mm) ID, a width of 14" (6.35mm), and a 30 diametral pitch.
I am not sure about the correct knurls from knurlcraft so I called Hardinge and they have them available for 24 bucks each. He also mentioned that the c30 knurling tool is still sold and that it is $436 bucks new:crackup:
I ordered a set anyway. It seems there are "form type" knurls and cut type knurls and most of the cut type I could find were in metric sizes.
If anyone has any other suggestions on where to get 3/4x1/4x1/4 knurls that are cut type, let me know. Also, what the heck is "30 diametral pitch"?
I had to machine a shars cxa holder to fit the 1" shank and it was really a nasty affair on my mini mill. It spit out a million needles of steel but came out okay at least. I managed to get a few steel splinters in spite of being careful. I guess I need to make a dedicated holder for the shop vac hose for this stuff.
Got the new knurls and they outsourced apparently. They are marked form" on them + kn so I guess any straight knurl will work that isn't beveled. I got to play with it for a short time last night and made my first attempt. It is clearly not what I was hoping for. Here are some pics:
I am unsure about adjustment of the 2 arms holding the knurls. You can rotate them and you get more of a diamond shape on the knurls if you rotate them differently than the pics above. I was mostly trying to get both wheels to make contact at the same time and they were perpendicular to the tube. I will play with it more this weekend and try to get it right. The pattern actually looks fine if you don't magnify it but it isn't a nice diamond yet. So far my set up consists of trying to get the tool to center, and making sure the wheels contact at the same time. I was running it at 115 rpm with the power feed on.
If anyone has any info on how the wheels should be rotated or proper way to setup the tool, it would be great. Fyi, I contacted Hardinge and they faxed me a parts sheet but had no instructions for the tool.
The photo above shows that one of your knurling bits is cutting into the piece more than the other one. Either your tool is not on center, or you need to adjust the height of the knurl by rotating it a bit.
I also don't see a bevel leading into the knurling, which is highly recommended. You start the knurl by engaging only about 1/3rd of the width of the knurling bit, plunge in quickly and deeply to form the knurl without any double tracking and then do the axial feed. The bevel helps start the knurl properly, imo.
Knurling takes a lot of patience, and practice. You will need to analyze what is wrong with the knurling and then make an adjustment.
And, in my opinion, the piece needs to be fixed in place by using a live center in your tailstock. And before you start knurling, you will need to indicate the piece from end to end after you have turned the piece to the desired diameter; I check not only on the side of the piece, but also on top of the piece as well.
Thank you very much for your suggestions. I am still trying to master this but I am at least getting closer. I get that you need to have the knurls touch at the exact same time. How much to angle them i really don't get. Here is my progress so far:
Not there yet but at least it made an actual diamond...
Those are looking much better!
I ordered some different knurls and had a breakthrough with 12 tpi kn knurls. They are big enough that there is no question they will track and I am getting really flawless knurls now. I found they are almost too sharp and tried a wire brush and it smoothed it down but knocked a few points down. Here are some new pics:
Anyone with a cut knurler: try some knurls in the 12-16 tpi range and see for yourself how easy it is to center, cut and get pretty tack sharp knurls. The bigger sizes make setup easier and it looks more custom imo. I will cut some more and shoot them without the wire brush. It was silly how every point was sharp and perfect before I wrecked some being too ambitious with the brush...
Those are looking much better indeed :twothumbs
How much and how fast were you feeding the cutter radially (x) and then across the surface (y)?
Did you do only one pass, or did you reverse the spindle and repeated the cut?
My setup at this point goes as follows:
1. Make sure everything is concentric and the bar/tube is indicating nice
check that the knurler is centered perfectly by using a center in the tail stock. The tool is cut a 60 angle on the end of it as you can see in the pic below so you just make sure the center in the tailstock is fitting in the v perfectly:
2. The next step is key: adjust the cutters so they cut 1/3 of the width of the knurl wheel to set the depth. It works out about half the pitch of the knurl. I will have to measure it but this seems to be optimum. This is the "depth" of the "X" i.e. adjust till you get 1/3 width of the knurl making an impression. I also try to make sure they are sitting at mirror angles as this tool doesnt' have gears to keep them at the same opposite angles.
3. Fine tune the cutters so they engage at the same time. At this point, I loosen the two screws holding the angled rods the knurls sit on and adjust them so that when I turn the chuck by hand, they engage at the same time.
4. Feeding:
I played around with different feed speeds and the ones in the pic were at .0139 according to the table on the lathe. You can get different diamonds by speeding it up or slowing it down but with the larger knurls it seems to dig in and track so you don't get double tracking and you can control the shape of the diamond this way. With the 30 diametral pitch the tool came with, it is really finicky. I got some plain 20 tpi and 12 tpi knurls from enco and am getting much better results. FYI, these are plain 3/4x1/4x1/4 straight knurls with circular pitch and listed under "form knurls". The main thing is they are sharp edged and not rounded on the edges. The larger teeth seem to track better regardless of the diameter of the piece and I like the look of the larger knurls. The stock knurls are almost too small and it is so small you can't see it properly without a macro.
5. Keep the wheels clean while cutting: I found that by using compressed air and wd40 in alternating blasts on the knurls while it was cutting, I got much cleaner cuts because the wheels were kept clean.
I have repeatedly cut to get to this point using up 10 feet worth of 2" round bar and the larger knurls are finally giving me repeatable results regardless of diameter.
In answer to to your final point, everything was done in a single pass. You don't want to make multiple passes with a cut knurler. I tried it and the screws on the knurls tended to unravel as they are left hand thread and the cutter would bind.
Here is one final shot with better light:
Dorian makes a nice "straddle knurling" tool (CNC-100-7-R):
http://www.drillspot.com/products/5...-r_straddle_forming_cnc_modular_knurling_tool
Capacity is up to 1" diameter ... and it's on sale at Travers for $79.99 ... about 91% off the retail price :) The Travers order number is 55-370-934ZD
Their site is finally back up from maintenance. It's corrected now & price is back up to $792. I knew it was too good be true, never see that great of a discount on Dorian products. It was worth a shot though. :(
That price is not from their website, it's from the paper sale catalog that came two days ago. The front cover states "Sale prices valid from 04/01/11 thru 04/30/11. Phone Travers, give them the model number including ZD (meaning an inventory blowout item) & tell the salesperson it's located on page L12 in the April 2011 Metalworking Brochure. Blowout price is $79.99 :)
I'll fax the page if you want.
