Zendude
Well, they better because I want to see more of JHanko's Ti D10s! :popcorn:
+1
The first time I felt true lust for a light was his Ti D10:drool:
Hi,
I bought Nitecore D10 s/n 00712 when they first came out. I loved the small size and simple interface. But, the switch has never been reliable and requires a lot of force to press the button.
I did the normal things to make it better like using silicone lubricant, different orings, used contact cleaner, etc. This did help some for a while. When I replace the battery most times the switch does not work correctly and I have to open up the flashlight and piddle with it.
Are the new (currently shipping) Nitecore D10's better?
Tell me what other light do you need to do all these voodoo tricks and magic to in order to get working?
These are $60 flashlights. If you bought a car, a nice one at that, and you had to fiddle with the ignition, oil the o-rings, change the type of battery you are using, etc just to get it to operate, would this be acceptable to you? I think CPF is the nicest bunch of customers out there, of any hobby or market.
Sorry Marduke, that argument doesn't hold true here. You make it sound like a LED that doesn't turn off or lights that don't activate or function properly is the fault of the customer.
What people expected is a light that works as claimed. I guess JHanko's expections were off since he "expected" a light to turn off.
Maintenance on lights is a simple clean and lube. And you should be golden for months or years. Out of the box, I don't expect to have to maintain or FIX any light and in fact never *had* to get them working, except for Nitecores. I do anyway as a preventive measure but it was as simple as putting on some lube. Not having to take out jeweler's screwdrivers to fiddle with a component, or rotating to (as one user put it) find the sweet spot. The sweet spot, so my light can turn on? You have got to be kidding me.
That's your idea of proper maitenance? Maintain means to keep in (the same) condition. It doesn't mean to fix defective products out of the box.
