flatline,
Thank you for that point about HDS lights circuit, and run-time.
I read on the light-reviews website, about two HDS lights. One was the former Ra Clicky with it's review dated May of 2009. The other was the (apparently) current HDS Rotary, with that review dated (on light-reviews website) as August of 2011. In both reviews the output and run-time were nearly identical for that beam level which I need most (close to 15 lumens).
But, if there is a different circuit in HDS lights now, then I'll call HDS and inquire about any possible run-time difference between the old and new.
Kaichu dento,
Your point about the brightness of 2 lumens, and your use of the HDS medium modes lasting for a month, keeps me hopeful.
With age, my eyes have come to need of more light, and I have been using a light currently that is estimated at about 3 lumens. But I anticipate that the HDS light may provide better use (beam pattern, reflector, etc) of lower levels of light than my current light.
I too hope my need to re-charge batteries will be less than estimated.
My consideration is actually for the HDS Clicky, rather than the Rotary. I have used twist method lights so many times each night, and for so many years, that the single button method appears more appealing than staying with the twist function. I do know that the HDS Rotary can be used as a Clicky, but I am taking into consideration the possible durability of the Clicky version being better than the Rotary, and (from what I have read here) that the run-times on the lower levels of the Clicky versions would be better than those of the Rotary, because of the extra power needed from the battery to keep the Rotary function constant.
Blades,
Thank you for offering the Zebralight option. Those are the most attractive battery sleeves I have seen (I have not seen many though).
I had considered Zebralights various models (though I hadn't looked at the SC80 to find the battery options you mention).
The warranty though, on Zebralights is not what I prefer. But the companies lights have remained impressive from what I have seen thus far.
I wholeheartedly agree, that it is always good to have more than one light.
FaithinGod
