recDNA
- Joined
- Jun 2, 2009
- Messages
- 8,761
Nah...it's the low profile tires and blacked out wheels!Amateurs.
Everyone knows it's the rear wing, and stick on air intakes, that make a 4 banger, front wheel drive car faster.
No photo on HDS website.... that's OK. Here is one in the wild....followed by a shot in the darkness.
That looks great!
It seems that this is a great solution equally doing what McGizmo Sundrop is doing in a different approach, and much less expensive!
I really want to try this with my two HDS.
Is that the hyper red with flood or the standard custom red with flood? Looks great
@FroggyTaco
Thank you,i will check it.
@ForrestChump
Thank you for sharing your knowledge! I hope we all make not the expierience of an EMP!! But you are right,when us hit an EMP,Flashlights are not the major Problem.
Henry stated their Lights as EMP proof,and for my knowing,its the only Brand that says our Lights are EMP proof.
So im not sure if Henry do something special at the Electronic side,against the EMP (Anti-EMP-Diode.....),or is the design of the HDS (or flashlights) generally EMP safe.
I trust Henry 100% and the Light specs .
Thanks from Germany
Marc
This was answered already, but I thought I'd add a little more information:Sorry for the newbie question;
Can one order a rotary CR123 and a clickie 18650 for the same head?
The Rotary has a second "brain" in the tail of the flashlight that communicates with the head so that the dial can do its magic. Without that second brain, the Rotary head won't operate.
Ok, so the rotary tail and head combo are tailored to one another and only that combo (rotary head and rotary tail) will function together?
Yeah, I found this confusing as well because I have never come across this being clearly stated. But I have not read 25k posts in these threads either.![]()
Is that true even if light is purchased from a dealer?Probably unnecessary to share here as everyone knows that HDS takes care of their customers. I received a rotary back from HDS this week and all of my concerns with the light I sent in were addressed. Henry really went above and beyond.
Does Henry sell rotary tails? It would be neat to use tac interface with one tail and regular rotary with the other. I wouldn't need 2 heads.You can Lego any rotary style head with another rotary style tail. I swapped my tactical and rotary tails recently, and it works.
However, the Tac head still behaves as a Tac and the rotary head still behaves as a rotary. The tail encoders function identically, the brain in the head interprets the same signal to yield different behavior. I suspect this also works with the button only styles but haven't tested it.
The more you know...
I believe Henry stands behind his lights even if you buy one second-hand.Is that true even if light is purchased from a dealer?
