Tejasandre
It's had rest and relaxation in Hawaii. Now it's time to put it to work! I may have missed it elsewhere, but is yours a rotary or a clicky?
Lol. Rotary
Do you ever change levels by entering programming menu and ramping on the fly?
Wouldnt a rotary be easier?![]()
Is the rotary easier? Yes. Is it better? That is a matter of debate.
I respect your preference, differences make the world go round.Four settings are sufficient and can be representative of the low, middle, and high. No problem.
A few aspects of the UI make it especially perfect to me.
Mine is programmed so the Rotary control is one setting and a low/low is another. It is also set for hold when already on as max output and hold from off the last preset that was on.
So I can get a momentary of the last setting from off which is one I use all the time or a single click latches to that level. Then if I need more light I can just hold the button while already on for a momentary blast and release to get back to the last level.
It is tougher to explain than to use for sure.
The beauty of it is the use of momentary while on or off and for different things.
Then the Rotary sort of speaks for itself I think but know it is just 1 of the 4 presets you ca program into the UI.
So I can get to the rotary level anytime or go low or full blast without ever turning the light off and I can make sure the rotary is where I want it before turning the light on at all.
You really need to play with one for a few minutes to grasp the genius of the design….
...so yes, you need another HDS
...the user has added momentary memory to his programming and is using the C preset for rotary...
Also, muggles understand a rotary set to preset B, one click, dial click off.. done
unless you plan on twisting a rotary under muddy water, or other forms of Flashlight Hell.. ;-)
I do have a high noon rotary. It's great fun but I never know how much light is going to come out of the bezel when I hit the switch.
the rotary mechanism itself as it squishes and flexes under clicking pressure.
The first half of the rotary dial is all the same to me. No matter how deeply dark adapted my eyes are, I don't appreciate the difference between 0.02 lm and 0.75 lumens.
Muggles get whatever is cheap at Walmart. HDS is for me.
Have you considered how copper in circuit boards reacts over time to high humidity conditions in salt water environments like homes near the ocean?
I like the option to ramp UP instead of Down
Preset D tripple click from ON makes no sense to me, since I use firefly levels on my lights when I wake up in the Dark to go to the bathroom (yeah, I could make it without a light, but hey, I want to play)
Using UltraLow After Preset B, makes no sense in that application, as it would have blinded me and constricted my pupils...
Hmmm, maybe start a seperate HDS programming thread?
That is why there are 2 O-rings sealing the tail in the rotary and not 1, and... any copper is nickel then gold plated. Caves can be wet damp places as well... which is just another reason for me not to go into one!
Tejasandre, your inbox is full so I emailed you. : D
